Clutch replacement cost???
That's actually not bad. For those who know how to actually drive a manual properly (e.g. without slipping and abusing the clutch) it should go well over 100K miles minimum. I'm not talking about babying the car either. You can achieve that kind of longevity and still drive the car the way it was built to be driven.
Former Vendor
The $3500 sounds about right. I was told that it is almost easier to pull the motor to swap it. Im sure we'll start to see guys swapping soon, with all the supercharger installs, clutches aren't going to last that long.
E-Ray, 3LZ, ZER, LIFT
Received 9,648 Likes
Just checked the Service Manual, yep looks like you can keep the driveshaft etc mostly in place but there are three pages of "remove the radiator, disconnect the air conditioner components and remove the refrigerant etc etc etc!"
There was a show... TWO GUYS Garage that showed how they did a clutch on a C5/C6. A Z06 as i recall, so should be no different for a C7, Z51 or not ( IFF you do not drop the torque tube /tranny ) They used a series of jack stands under the driveline so they did not have to disconnect all the cooler lines, I believe there should be enough flexibility in the lines to do that.
I recall when I was adding headers to my '67 Corvair there as a bolt on the sheet metal engine cover that I couldn't get back in. Called my Uncle who asked his best mechanic to come to the office. I could hear his reply when my Uncle asked, as said, "with a tricky hand!" Same Uncle who helped my assemble the Olds engine I stuffed in my 1st car a '41 Ford Opera Coupe!
At a dealership you'll pay full price even if they do it quicker. A quality independent who has changed clutches in C7's may be cheaper. I recall my Uncle had one mechanic who was slow but did a very good job. He was concerned since he was taking up a service bay and was much slower than some others. However if my Dad needed something done we could not do, he'd recommend we take the car to this fellows house where he worked on the weekends, as the quality of his work was great!
Tophog (01-22-2020)
Received 19,416 Likes
'20-'21-'22-'23-'24
Revival of a 2016 thread.
