Tire Pressure
Tire Pressure
What tire pressure is everyone running on the street?
I'm using the recommended 30psi.
Has anyone experimented to see if a different pressure works better for maximum tire life?
Source: The Seventh Generation of America's Sports Car Corvette Stingray by Larry Edsall
As recommended, 30psi.
(2015 Z51)
(2015 Z51)
32-33 lbs
'14 Z51 30 psi. After seeing the tire wear, I think GM/Michelin were correct raising the pressure up some. Reading backwards, looks like all the Z51's are 30 psi.
The door sticker on my '16 Z06 says 30psi.
Last edited by bradc6; 03-15-2016 at 09:43 AM. Reason: I don't want some forced ebay link in my post.
You may want to try adjusting to 28 PSI to see if that improves the ride any. With run-flats, i doubt it but if you want to try a softer ride.
My door plaque says 30 PSI which seems ok for a nice street ride...
Warning... with Runflats, you need good tire pressure or if you hit a pot hole, you'll damage your rim easier.
For drag racing, you might want a lower PSI
Received 1,877 Likes
2020 C8 of the Year Finalist - Unmodified
Our '16 Coupe built Jan 26 has a door sticker showing 30 psi. We have the 19 and 20 inch wheels too.
I run 30 to 32.
I run 30 to 32.
I believe it's the base Stingray with 18/19 wheel combo that now carries the 35psi recommendation based on a previous thread we had on this subject. The Z51 and Z06 has remained 30 throughout the C7 model years.
Rebel Yell (03-31-2016)
Received 2,240 Likes
That is correct: 18/19's = 35 cold
19/20's = 30 cold
Why? I have no idea.
I think it only notifies you if there is a different pressure in one of the tires. If they are all over or under-inflated there wouldn't be a message.
The following 3 users liked this post by Woodson:
