Does the 8 speed auto not have Rev Match?
I test drove a8 stingray and you can use the paddle to shift up or down in any mode as U guys well know that have them. The salesman thought U had to be in M mode to use the paddles but we found out differently. Dumb question, what is the rev match?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
If you drive in 4th and select 3rd, the rpms will go up to allow you to maintain the same MPH go to a lower gear and do it smoothly.
Elmer
Thread resurrect warning
I knew this was going on with my A8. It doesn't matter if I'm in Drive or Manual, as soon as I start blipping paddle downshifts, it'll start rev matching. Love bringing it down to 4th->3rd->2nd (appropriately), that's where magic happens (I think).
Blip it as many "-" times you want until you get denied!
And if you try to select a range too high or too low it will simply snark back at you "shift denied"
