Corvette/Stingray door sill
My new 2016 Z51 is in the shop and I am trying to find out what is on the door sill before ordering parts. Does it have Corvette or is it Stingray? HELP Please, Thanks JD
Received 1,694 Likes
St. Jude Donor '15
Corvette is the default. Stingray is the upgrade.
JohnnyDee (10-22-2015)
I'm not sure how you expect someone here to know which sill plates are on your car. As others here have already said, the "Corvette" ones are standard and the "Stingray" ones optional. Which ones are on your car is anyone's guess.
If you have your window sticker, look under "Options". If it says, "Door Sill Plates" with a price, then you have the Stingray Door Sills. Also, if you have the Build Sheet, the Stingray Door Sills will be listed as "Sill Plates Design 2" with a code of "V8X".
Good luck!
Good luck!
Call the shop where your car is and ask them to go look. Problem solved.
I see you have been thanked 30 times in 20 post, you will have to excuse me if I don't thank you for the above post. I got my answer in the first post that "corvette" is standard. That's all I was looking for, you didn't have to be an A**h*** about it.
My sill plate has Corvette and I am happy with that as my rugs say stingray.
I'm not going to get into a pi**ing match with you. You asked which sills you have in your car, not which sills come standard vs. optional. My response wasn't me being an a**h***, it was a legitimate response to the question you asked. Had you been more clear in your original post, I could have provided a different response.
