Tire wear warning after lowering on stock bolts
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Somewhere around 4,000 miles, I lowered my 2014 all the way on the stock bolts.
At 4,297 miles, my local Chevrolet dealership did an alignment job for me and adjusted the toe. They knew I had lowered it on the stock bolts.
After a 1,400 mile trip to Richmond, Virginia, this past Wednesday and Thursday, I had 13,500 miles on the car. I spent Friday evening detailing the Corvette for a show the next day and decided to remove my wheels for cleaning. I was horrified to find that the inside portion of both front tires were worn all the way down to the wear bars. Evidently the camber wasn't adjusted and I've prematurely worn out my front tires.
I'm going to attempt to find a reputable shop to make the appropriate adjustments before my 1,400 mile trip back to Oklahoma Monday and Tuesday.
If you have lowered your car on stock bolts, please check the tire wear from time to time even if you've had the alignment checked and/or adjusted.
Do you have a copy of the alignment sheet from the dealer when it was aligned? It would be nice to see where the camber was set. (or not)
Lowered car always means more negative camber which is evidenced by the tire wear you posted.
2015 C7 of the Year
No, I don't have the alignment sheet. All I have is my copy of the job sheet that says they adjusted the toe. I don't think they did a thing to the camber. I now know a lot more about alignment and tire wear than I did before all of this. A lesson well learned.
I'm Batman..
Pro Mechanic
My base model fronts looked exactly like that when I took them off. I think I got about 10K out of the tires after I dropped it on stock bolts, however, I cut the bumps on my stock bolts to lower it even more. I've since swapped out to Z51 wheels and tires and its been aligned and holding true. (checked them today)
Jeremy,
Holy cow! Thanks for this info..I lowered my car down all the way on stock bolts at about 500 miles and now I have 3000...I looked at my tires today and they look fine....
I was planning on having the alignment done at my next oil change...now I think I will bring it in for an alignment next week!
-M
-M
Jeremy,
I was planning on having the alignment done at my next oil change...now I think I will bring it in for an alignment with the Pfadt settings next week!
-M
-M
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
I'm going to attempt to find a reputable shop to make the appropriate adjustments before my 1,400 mile trip back to Oklahoma Monday and Tuesday. Here are the Pfadt Corvette Performance Street alignment specs that I am going to go with now that I have learned a valuable lesson (provide the alignment settings that you want when you have an alignment job done)...
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
Received 19,448 Likes
'20-'21-'22-'23-'24
Too bad those tires wore on the edge so soon. Sucks having to replace them when the rest of the tread looks like it has lots of life left.
Received 7,767 Likes
CORVETTE TODAY Host
St. Jude Donor'15
^^^ That is highway robbery.
Received 1,739 Likes
St. Jude Donor '15-'16,'18
I'll bet your Chevy dealer didn't have a clue as to how to do an alignment or they didn't have the proper equipment. A red flag is you didn't receive the print out with the complete measurements. Total toe? Steer ahead? How about the rear? Good to find a good shop!
2015 C7 of the Year
I appreciate the feedback and replies. I'm at Tire Pros in Fisherville, VA, and they really know their stuff. Their alignment rack is flush with the floor when you drive up on it so it's perfect for lowered Corvettes. They were very careful with my Stingray and even said I could watch stay in the bay and watch them work on it.
My current alignment settings are very close to the Pdaft performance street settings that I had originally posted. I removed the settings link because those settings will definitely give you excessive inner wear. After talking with the techs here at Tire Pros, we settled on 0 camber so that the tire rolls flat for now. They don't have any Michelin tires immediately available, so I'm going to hope for the best on the way home and keep a constant eye on my tires.
I'll let everyone know how things go on the remaining 1300 miles back to SW Oklahoma. Thanks, again!
