Maintenance on Z51 vs non-Z51
Hi, I am new to this forum so I want to apologize for any mistakes I make, and for making a new thread if there is already an existing one similar to this.
I am about a week away from buying a c7, and I've been having a very hard time finding any information about the maintenance costs the z51's larger brakes (that I've heard have only half the life of the non z51's) and different tires and the dry sump oil system. Mainly what I am wondering is how long do the brakes last on the z51 vs the non z51? Assuming tracking the car once a month. Also, is the tire life much different? The price difference between the brakes and tires on the z51 vs non z51 aren't a really big issue, the issue is the life of each of those components. Also, I've read that the dry sump system requires 3 more quarts of oil, which isn't really a big deal either, but I wanted to check the validity of these things.
I've found a perfect car for me but it’s the z51 and so I've kind of ignored it because I assumed it has significantly more maintenance and I’m really trying to steer away from high maintenance, but I figured that I should try to find out if my assumption is correct before I disregard the z51's.
one more thing I was curious about was the usability of the z51 tires in the rain, I’ll be living in Texas and won’t really need to worry about it too much, but if they are significantly worse than the non z51 to the point where they aren't even functional if under 40 degrees or raining than that's something that would be good to know about.
Thanks a lot in advance to anyone who would be able to help me out with this, I really appreciate it!
Matthew C
Matthew C
I would buy a z51 again, the difference in part prices wasn't enough to worry about.
I bought new Micheline AS3's tires for this car because I didn't want the run flat tires on it, they were the exact same price as I paid for my c6 tires a few months earlier
I bought the z51 for the technology and the resale value of the car when I sell it
Hey guys thanks a ton for all of your input. I'm definitely re-thinking the z51 package now, but I'm still wondering about the difference in the life of the brakes. I heard that they only last half as long, which is worrisome. Also, is the z51 any less reliable? How about the handling in the rain or weather under 40 degrees? Thanks again!
Moderator
Michelin tire info:
Both versions employ an asymmetric tread design that features a low-void outboard shoulder for cornering while their notched center ribs and inboard shoulder promote high-speed performance in dry conditions. Wide circumferential grooves and lateral notches help channel water through the footprint to maintain wet traction. Sizes for the standard Corvette Stingray use a single tread rubber compound that blends dry traction, wet traction and tread life; while the sizes for Z51 equipped cars feature side-by-side tread compounds that deliver near-racing-slick dry grip and handling levels, without abandoning tread life and wet handling.
Both tires feature twin steel belts reinforced by spirally wound Twaron cord. The angles at which the steel belts are molded into each version have been tuned to balance performance and comfort. The steel belt angles used for the standard car emphasize ride and treadlife, while the angles used for the Z51 tires focus on increasing performance and at-the-limit handling.
Twaron is a polyamide cord that offers a lightweight, high-strength reinforcement above the steel belts to enhance high-speed handling, wear and durability. It is applied using Michelin FAZ Technology (Filament At Zero degrees) that allows Michelin engineers to tune tension and strength by winding the cord around the tire circumference much the same way fishing line is wound onto a fishing reel.
Michelin Zero Pressure Technology reinforces sidewalls by adding run-flat inserts that allow tires to temporarily carry the weight of the vehicle in the event a puncture results in complete loss of tire pressure. The Pilot Super Sport ZP is designed to allow Corvette drivers to continue their journey for up to 50 miles at up to 55 mph. Both tires feature asymmetric run-flat inserts and casing components designed to broaden tire performances by focusing distinct functions on the appropriate sidewall. Inboard sidewalls feature a more rigid insert that increases sidewall stability to provide the majority of run-flat capability, as well as to transfer torque during acceleration, braking and cornering. Outboard sidewalls feature a softer insert that increases sidewall flexibility to maintain footprint size when cornering, as well as to enhance ride quality and tread life.
Both Z51 and base tires are UTQG 300 AA A rated.
I drive my Z51 year round in the DFW area. Driven responsibly, rain and 40 degree temps are not a problem.
I'm not putting down the Z51, as for track use it would be a logical choice. But for street use, my bang-for-the-buck calculations suggest that it isn't.
I would go with Z51 even if you don't track the car. Read about the eLSD that only the Z has. Benefits car handling even when not at the track.
BUT...if you plan to drive the car like your great grand dad, then the non-Z51 should do.
If you're torn between the two, I'd go ahead and get a Z51. I have one that will never see a road course. I always go for the most features I can comfortably afford. That way I have no regrets and am not left wondering "what if".
Right, and if not tracked the Z51 might be overkill. For me it was and I picked the ZF1 (Z51 Appearance Package) instead. For street use I don't need a 10-qt. dry-sump system; larger brakes that resist fade in a racing environment, create more brake dust, and wear faster; eLSD with cooler; lower gearing that would marginally affect gas mileage on the street; and shock and sway bar upgrades that will affect ride with only a slight performance advantage. The car will do >1.0G on the skidpad in any configuration, better than almost any other car on the road, so for my needs going with the non-Z51 made more sense for street use. The Z51 will raise trade-in value but only a fraction of the original cost, so you're paying for it on that end, too.
C7 has a Weather driving mode. That should help in rain. Can't speak from experience as I have not driven on any of the 4 rainy days we've had here the past 13 months.
Another tip - The C7 without Z51 option is NOT reserved only for those that drive like old people. We hear that stuff sometimes from guys with the Z51 option that feel the need for justificstion. You can ignore that kind of remark. For the street you can drive the cars that have "just" the LSD aggresively. eLSD will add some benefit at the very upper end of the aggressive street driving scale.
...but you would have gotten all of the Z51 extra features for less than $1800 or less than 3% difference. A potentially higher used car value, better brakes, trans cooler, differential cooler, limited slip differential, better shocks, better sway bars and the opportunity to add the magnetic ride control suspension. For me, the Z51 package was a no brainer!
Those are valid points for you not buying the Z51 package for yourself, but you would have gotten all of the Z51 extra features for less than $1800 or less than 3% difference. A potentially higher used car value, better brakes, trans cooler, differential cooler, limited slip differential, better shocks, better sway bars and the opportunity to add the magnetic ride control suspension. For me, the Z51 package was a no brainer!
judgeman70: A base c7 with 460 horsepower doesn't have limited slip?
