Fuel smell after fill up
Garage smelled like someone poured gasoline all over the floor when I went inside after fill up from previous day. I saw that someone else had a similar problem. Was there a fix put out by GM? Cecil...........
The recall is for the anti siphon grid, inside the filler hose, slipping out of place, and possibly falling into the left side tank. That wont cause a fuel leak, or fuel odor.
However there is a TSB for a possible fuel leak in the high pressure fuel line located under the intake manifold. Best to have the dealer check it out. If one would catch fire, or enough are discovered leaking that may justify a recall.
Ed
Ed
