How to identify performance exhaust
My new C7 is supposed to have the factory performance exhaust. How can I verify that when I pick it up since I've not seen one before. Sorry for the newb question.
Two ways...
From the outside: look at the tailpipe at the rear end, just behind the outside 2 tips, you should see a couple valves hanging on the sides, and if you look inside the pipe, you will see a baffle that will open and close (pretty easy to see)
From the inside: with the car running, go in to the settings and you have an option to change the Engine Sound Management settings
1.press the house button under the infotainment screen
2.select settings
3. select drive mode
--You will see an engine sound management option if you have the NPP option
Enjoy the new car. You will love it.
2.select settings
St. Jude Donor '09
The easy way is like Glen shows, the tips are an inch bigger in diameter on the performance exhaust and completely fill the space. If you take your tape measure, they are 4" compared to 3".
Easiest way visually-- the 2 inside pipes have a larger space between them.
Apart from the tips being spaced differently,
and the NPP tips being larger in diameter,
and the NPP tips having the NPP valves in the outer tips.....
Are the mufflers different (in size/dimensions) ?
