OK, you Fatmat installers weren't exaggerating!!!!
I read all the threads and bought into the hype enough to buy the Fatmat for sound deadening. While I believed that it would help, I figured some of it was placebo affect with the rave reviews......but you guys weren't lyin'!! Significant reduction in the road noise as well as significant improvement in the audio......as you stated......with the base being more basey than boomy.
After finishing it today, I took my son for a ride and he was the first to comment how much quieter the ride was......I noticed the audio improvement. I did behind the seats as many have sown and completely covered the back of my Lloyds Ultimate rear mat. I actually peeled it and stuck it to the back.....every sq inch.
So thanks Rad22, GlenE, and all the others........it truly did as much as you said it would.....well worth the $60, time, and effort........my apologies for doubting.
not sure why anyone would think that several posters that don't know each other would get sucked in by a placebo.....
I only post things that work...if I posted what I've done that did not work, the forum would be flooded with threads....LOL
Something I did in my last sports car and it worked very well.
Very nice job C7 Jake on yours , great pics !
This is something I want to do comes spring. Imagine someone has posted some detailed instructions on removing the seats etc. with this mod, would you mind posting a link here. Thanks !!
I searched already, so don't even say it
Is there a thread somewhere, with a step by step method for getting the panels off, and putting the sound deadener down. Which products are best etc....
https://www.corvetteforum.com/forums...ening-mod.html
my original post that started it all is in his 1st post...
if you decide to do entire rear (but not necessary)
https://www.corvetteforum.com/forums...r-removal.html
Nice. Where did you buy the Fatmat? The price on Amazon for the 80 mil is now up to $110, instead of the $60. Has anyone done this with Dynamat? I know that it is more expensive, but from what I have seen on comparison's, the Dynamat Extreme is far superior to anything else. Looking on Amazon, the price difference is about $40 (unless someone has a source for the Fatmats for the original $60.
I'm a fan of Glen's detailing methods, so I followed his lead and installed the FatMat last weekend. Just a short drive, did not experience all the varying road surfaces but an improvement was evident.
Cheers
Cheers
However, Dynamat Xtreme and B-Quiet Ultimate both have better sound dampening properties than Fatmat.
Here is a great thread from an audio forum. I won't get into the debate of which brand is better, or whether to do full v. partial coverage or whatever. You can check it out yourself. CLICK HERE
I used B-Quiet ultimate in my project here simply because I found it cheaper than Dynamat at the time and their properties are nearly identical when it comes to vibration damping.
For an easy sound absorption solution (damping plus absorption = sound deadening) I would look at the block-it mat, since the back is where a lot of the unwanted noise comes from and it resonates with the rear window. For a more in depth job see my tread.
I got nothin' but positives .....sorry if it came across differently.
