What's the deal my trunk WONT OPEN!!!
Can you hear the latch moving when you hit the remote? Did you try both buttons/one under the hatch, and the one inside the car? If you're not hearing anything, I'd look for a blown fuse. Assuming it's inside/not frozen shut.
the key opened the trunk(i did not know about that key thanks. But both remote and inside button do not. I do not even hear anything when I push them. One more thing when I hit the trunk button on remote lights flash but trunk does not budge. Any idea where the trunk release fuse would be?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Moderator
Not sure about the inside release but the remote trunk release on most (all?) recent GM models requires you to hold the button for a short time before the trunk releases. This was put into place because of people inadvertently opening the trunk when the fob hit something in their pocket.
Moderator
This was after it had already been opened 2 or 3 times.
They ended up taking the car back over to the factory to get it repaired. They told me there was a broken part on the release mechanism.
It ended up it was great because during the extra 1 1/2 hour wait, we saw a couple areas I don' t think we were supposed to see at the museum.
Did you ever get this figured out ? Mine is doing the exact same thing . Key fob , inside button , and rear plastic button wont open the hatch. Doesn't make any noise at all either. I also lost the metal key lol
weathermaker (06-26-2022)
Any resolution found for this issue? I am now having the same problem with my 2015 Z51 Convertible. Only the mechanical key works. The other option, fob, button by license plate and button by steering column make a noise but do not open.
Ron_Attleboro_MA (06-26-2022)
RIP OP. He was a fun guy to chat with in the OT section
