No more hopping,sliding,rubbing,grinding when I turn my wheels and tires on my Z51 C7
Received 3,144 Likes
Finalist 2020 C7 of the Year -- Unmodified
I do not mind the ride of my Z51 2014 vert but could not stand the binding,grinding,rubbing,hopping, and jumping when I turn the
wheel sharply or go in a circle or annoying road noise when the weather is cold.I was not going to purchase the Z51 vette but the dealer I purchased the car told me that If I go with Michelin pilot A/S 3 all season aggresive tires instead of the O.E.M factory performance tires that problem will be solved.Well I got my car yesterday with the new tires on the stock black Z51 rims that came with the car 19's in the front and 20's out back.THE CAR DOES NOT MAKE A PEEP NOW WHEN TURNIG AND ALL THE BAD STUFF I MENTIONED IS GONE AND ALSO GIVES A MUCH SMOOTHER RIDE! If you guys track your cars or are very aggressive drivers then stick with the factory stock performance Michelin pilot tires but if not go with the Michelin pilot A/S 3 all season tires you will not be sorry what a difference!I will not be taking my car to the track so these A/S 3 tires actually got me to purchase my 2014 Z51,3LT,Npp,mag ride vert. I was following several threads on this issue and I know it says it is normal in the owners manual but unacceptable for my driving and enjoyment of my C7. Saw online from a very famous tire company that the O.E.M. tires are $1494.00 for set of four and the the Michelin pilot A/S 3 all season tires are $1070.00 for a set of four just in case anyone is interested in comparing the price of replacement.
IMHO, the Michelin Pilot A/S 3's are the superior street tire. Less road noise, no tire hop, less unsprung weight, less flying debris to damage your rocker panels, better tread wear, better gas mileage, drivability in all temps and road conditions. The only negatives are they are not run flats and less traction. Carry a 12V compressor and a plug kit. Keep the Super Sports if you track your car.
I am very happy I swapped out my RFs for the A/S 3. Much nicer ride and half the road noise. Cost about $100 after selling my OEMs.
Unless you do serious autocross the tire has enough grip. IMO
E-Ray, 3LZ, ZER, LIFT
Received 9,671 Likes
When it gets to 40 to 45 F I get chatter if I forget and turn to sharply when the tires are cold! I normally make a “K” turn instead when backing out of the garage on a cold morning! The C7 has a tighter turning radius than my C6 so if turning full lock it would be worse. In fact there are a lot of 4 wheel drive pick-ups down here with a minimum turning circle ~25% more than the Vette and they alwys have to make "K" turns when pulling out of a parking slot! Not much of a workaround for the super handling I bought my Z51 to perform (when warm!)
I changed my OEM runflats to Michelin Pilot A/S 3's at about 500 miles, I could not stand the hard ride and noise they made. 100% happy with the purchase, made the world of difference to how the car rides as a daily driver. I too carry a 12v compressor, plug kit and fix a flat. Not had to use it yet thankfully.
Would someone post a pic of the tire on the car thanks.
Ok, all this sounds good but what is the plan when one or more tires go flat?
Do you have the jacking pucks?
Are you going to leave the car on the side of the road until a tow truck comes to get you?
Is it difficult to jack up the car when a tire is flat in the middle of the road?
Do you have a spare mounted and balanced in the garage as a replacement when this happens?
I'm not trying to bash this idea of a better tire, just trying to see if it makes sense against the potential dangers.
Received 2,005 Likes
[QUOTE=A Solid Rock;1588579715]Ok, all this sounds good but what is the plan when one or more tires go flat?
I got a flat tire kit for my regular tires. I have a hockey puck instead of bought jacking pucks. I have a low profile screw type jack. I have a plug kit and a compressor. Considered some fix a flat in an extreme emergency but since I have been running non run flat tires for 15 years w/o an issue or flat......frankly I'm not that worried.
[QUOTE=Greg00Coupe;1588579783]
Were my initial concerns, but I also have never had an issue in 30 yrs of driving. I am considering ordering a set of the A/3's, low profile screw jack.
In general I agree with your approach. Unless you have a monster hole in the tire in which case a plug kit won’t do it, just use a large can of Slime tire sealant. Should handle most of the issues and is what I have in my other car which came w/o a spare. Don
Received 19,525 Likes
'20-'21-'22-'23-'24
Pretty reasonable price for those Michelin tires and good deal that they cured the tire chatter.
I put a set of the A/S 3's on my C7 over a year ago! Never changed back to the OEM tires, just got my 15,000 service and never had a problem with the All Season tires. Oh, the A/S 3's performed fine at New England Speedway last fall!
Not faulting the decision to use all-season or winter tires when it’s cold, they may be needed to handle the weather depending on the climate. However, depending on what the Vette was purchased to do, performance is not all it can be. There are different reasons for buying a Vette, but the Z51 particularly was designed for max performance and the tires are a part of that design. For what it’s worth.
OEM Tires, Especially on the Z51, Have Low Slip Angle for Optimum Performance
