How to do a burn out with a C7 auto
I have a c7 auto and recently visited the local drag strip and could not do a burnout to warm my tires. I tried in the track mode with the traction control on and off.... i also tried with the traction control off and stability control off. the stability control requires a 7 second hold down on the traction control button.
if i try to powerbrake the car it bogs on the line and only allows 1300 rpms.
if i lift my foot off the brake and stomp the gas it gives 100% power and leaves fairly good, but I know i can do better if I can warm up the tires before leaving the line.
i had to do roll out starts....
I noticed john hennessey does the same thing on his web site. Is this a program problem with the transmission or brake pedal pressure?
socal_tom (06-17-2023)
If you are going to do a lot of drag racing at the track I would install line lock. Not quite sure why you are bogging down using the brake stand method.
Does this track allow you to wet down the line, if so have you tried this with no success as well ?
I have A M7.Friend of mine has the A6.both C7. He said he don't have any trouble with the launch.Just puts the petal down and the wheels start burning rubber.Naturally I don't have
To say anything about mine being it's an M7.
WHAT DO YOU DRIVE, A SCHWIN OR IS IT A HUFFY?
Received 19,407 Likes
'20-'21-'22-'23-'24
No new meaningful info added to this nine year old thread.
