Service Rear Axle
Service Rear Axle
Last Friday, I was driving my 2014 Z51 in high 30 degree weather, and received a warning message that said "service rear axle." The warning message disappeared pretty quickly and has not appeared since. I spoke with a service advisor at the dealership where I purchased the car, and he said that 2014 model year with Z51 electronic limited slip had a service bulletin issued, not a recall. It seems that there may be a lose connector. He said that it was not dangerous to drive the car, and I'm scheduled for a service appointment on 12/3. I thought you might want to know this as there is no service bulletins posted on the Chevrolet owner's website nor on OnStar. Happy Thanksgiving to all.
Ron_Attleboro_MA (01-11-2021)
Chevrolet Corvette Power Train Service Bulletin 361376
NHTSA: Action Number: 10054489 Service Bulletin Number: 361376
Report Date: 2014
Dec 01, 2013
Component:
Power Train
Summary: Gm:some vehicles may display a service rear axle message. Dtc c0407 may be set because the connector on the pump motor is not seated properly.
Report Date: 2014
Dec 01, 2013
Component:
Power Train
Report Date: 2014
Dec 01, 2013
Component:
Power Train
Report Date: 2014
Dec 01, 2013
Component:
Power Train
I had the same service message on my 2014 3LT Z51 a week after I bought it with 2700 miles. Mine turned out to be a bad differential clutch pump. Took the dealer a week to trouble shoot the issue and even contacted GM Engineering. Since then...haven't had any problems.
2014 2LT A6 - 6,000 miles
Yesterday I went to take the car for a drive and opened the garage door to a strong smell of what I believe was transmission fluid and a small puddle on the floor directly under the rear end (translucent with a slight gray appearance). No warning message upon start up so I think I caught it early. I brought the car in to the dealer and after their initial inspection determined it required axle seals which will take a day or two for parts. Will update post as I know more.
Update 12/05/2014
Service Ticket: Leaking Axle Seal 3030090 1.2 Right, and Leaking Axle Seal 30300110 1.2 Left
Parts Replaced: 19301560 SL-N-Seal, 88862624 N-Fluid
Update 12/05/2014
Biker 911 (01-11-2021)
Service rear axle
