Center Steering Wandering
My wife and I were the first to test drive a brand new 2014 (non-Z51) Stingray with the 6-speed automatic. We were impressed with how effortlessly the car accelerated to highway speed, and in particular with the spine-tingling feel and sound at startup. However, we found one characteristic troubling, namely that we needed to make constant small corrections to keep the car centered on smooth, straight concrete highway at 65 MPH.
This is a problem that we've never had with our 1997 Lexus ES300 or with our 2009 Honda S2000. Is this behavior characteristic of all Stingrays, or was there an alignment issue with the car we drove?
Mine was out of alignment from the factory and pulled to the right. Required constant steering input. Took it to a local tire company and paid for a front end alignment (didn't want to do the whole dealer thing). Been perfect since. 2LT non-Z51 5000 miles.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Agreed. It is not normal.
The only time I notice that sort of thing is our freeways here, in the right (and sometimes) center lanes, due to the groves in the road surface caused by studded tires and semis
Moderator
It could be an alignment issue, or it could be the driver mode control setting. I find the steering to be "loose" and lacking good feedback in anything below the Sport setting.
Unfortunately we so excited about our unexpected opportunity to finally drive the C7 that we neglected trying out the different driving modes. Also, the drive was too short. My wife described the car as having a "floaty" feeling while driving on concrete slab, whereas I simply found myself continually making fine corrections to keep the car pointed in a straight line. We definitely want to do another test drive where we can compare the "comfort" and "sport" modes that we would expect to use most of the time.
Also, concrete road surfaces are typically grooved, and the wide tires tend to track in them, likely contributing to what you felt.
It has been reported here that the steering in Tour mode feels "floaty." Fortunately, you have a choice to set the steering I mode separately from the driving mode, if desired. I like it set to Sport mode.
Mine too, went to dealer free alignment, problem gone.
My first impression test driving ours before buying was the same. Changed the steering setting under "Tour" to Sport and all is well.
For others, Friday when we bought ours, salesman came back from wife's test drive and said she hit 110 on the freeway on ramp. She is really liking it.
Sounds like the toe-in adjustment is off http://www.townfairtire.com/wheel-al...oe-alignments/
The important part:
"Toe-in also provides increased stability because it discourages turning. If your vehicle has the proper amount of toe you should experience ideal straight line stability..."
The important part:
Agree....steering feels loose/floaty in Weather, Eco, and Touring.
Fat tires will track the seams and grooves in the road, so that could be a contributing factor.
But checking the alignment on all 4 wheels is a lot cheaper than replacing the tires.
I have had this experience also. Found it to be grooves in the road from studded tires. I wasn't sure that is what it was until I was driving my truck on a rainy day and could see the grooves because of the water setting in them. Even on dry pavement, if I don't keep centered in the groove, it will wander because of the wide tires.
