HUD memory question
HUD memory question
Can anybody explain why the HUD returns to just "mileage 0" display after engine is turned off. We have to manually reset it each time with engine start to desired display. Cannot find any instructions in owner's manual on how to safe HUD setting in memory so it remains in the selected setting from previous ride.
If HUD memory can be achieved, please give detailed instructions on what menu to access and how to auto recall that preset HUD. Appreciate any help in this regard. Never had this problem in our C6 but this C7 computer system is totally different, of course.
Thanks in advance Heidemarie
Do you have auto transmission? I do and Touring is the default mode for each ignition cycle unless I shut down in Sport mode.
I always shut down in sport mode (set on track HUD), but randomly, every 6-10 cycles it will revert to sport mode HUD display upon start-up. I can find no pattern to it.
Yeah it's not always symmetrical- same thing with using the mode selector. Even though I know exactly how fast/slow to turn, it sometimes goes in the opposite direction I want it to.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Are you saying when you start up that the display on the windshield is a "0"? If yes, this is the look of the HUD in Touring mode. HUD will morph with driving mode selected.
I don't have mine linked and generally keep things in Tour Mode and the HUD always comes up where I left it last (circular tach, lateral g-force indicator and speedo). Oh yea, '14 M7 VIN 11822
I'm Batman..
Pro Mechanic
Only if you have Driving Mode linked to the display. If not linked then the HUD will remain where it was at shutdown.
I also had the entire infotainment system freeze, turn off, and reboot. It did this once, while the engine was running and it was attempting to recalculate a nav route after I made a turn. It worked fine after its self-imposed reboot (took about 2-3 minutes, subjective and approximate).
I'm Batman..
Pro Mechanic
Just adding another data point to the collection. Mine does the same thing. M7, unlinked to drive mode. Occasionally starts up in Touring Mode display, even though I shut off the engine in the usual "dogleg tach" display. I can also confirm the occasional misdirection on choosing the driving mode with the dial selector. Turn it "up" and the mode goes "down". I would say each condition happens with perhaps 5-10% frequency of total use.
Heidemarie
'Yeah it's not always symmetrical- same thing with using the mode selector. Even though I know exactly how fast/slow to turn, it sometimes goes in the opposite direction I want it to. '
'I always shut down in sport mode (set on track HUD), but randomly, every 6-10 cycles it will revert to sport mode HUD display upon start-up. I can find no pattern to it.'
Yup, I have those two instances happening to my A6 Z51.
Dealer cant replicate when I brought it in for service.
Nice to know its not only mine...
Just bumping this three months on... Anybody heard of a flash fix? Do we think GM is aware of the problem? I just took it to my dealer to get the expected "Can't replicate. No fix."
Same here, I've not been to bothered by it tho as it's the way of computers. And anything on our cars now that's not mechanical is part of a computer.
Sure sounds to me like this PITA is worthy of a response / fix from GM.
Anybody from Customer Service want to chime in here?
