Avoid Costly Front Bumper Damage to Your C7 Corvette Stingray w/Curb Alert Mini!
Former Vendor
C7 Stingray Corvette Curb Alert Front Bumper Alter System
This kit is specific for your C7 Corvette, includes special wire and fuse for easy installation.
Introducing the cure for the common curb. Front end damage when parking is a very real problem for many cars on the road today, especially for vehicles who have installed ground effects or aerodynamic profile improvements on their vehicles. Curbs are something that are one of those road hazards that do more damage to sports cars than any other hazard on the road. In fact, just a simple trip to the corner store can become a costly errand if you over-estimate your front end clearance when parking: damage repairs could easily run $1000 or more; however, Curb Alert provides you a warning system that gives you three-deep warning tones as you approach too close to a curb with your C7 Corvette Stingray.
The Curb Alert is very easy to install and does not put a drain on your battery when the car is not on. Using a patented infrared technology, the front mounted sensor is calibrated to a warning distance of anywhere from 8-28" (you decide with whatever you feel comfortable with). The warning alarm is hidden in the car and will give you three gentle tones when you are within a specified distance to the curb. The system gives you a short beep every time you start your car to let you know the system is active.
The Curb Alert is one of a kind and is a gadget that will save you money in the long run, preventing front end damage to any car that is low enough to be vulnerable to a Curb. Do not take a chance, get the Curb Alert to prevent curb damage.
Universal Mount (All Makes and Models)
Warns with an audible alarm before striking a curb that could damage your front bumper and/or spoiler.
Prevents embarrassing parking lot moments and sounds when your bumper or front spoiler hits a curb.
Sensor can mount in a discrete manner in the front end of most any vehicle and does not require any drilling.
Advanced infra-red triangulation technology and specialized software embedded for reliable operation.
Warning distance is adjustable from 8-28 inches. (Bumper to curb)
Removable when necessary with out leaving any holes as evidence.
Automatic power-up on vehicle ignition; never a battery drain.
Alert sound volume can be set to High, Low, or Mute inside vehicle.
Installation kit includes installation procedures, all wiring, wire ties, sensor calibration procedures, and user guide.
We've got them in stock right here: http://www.northamericantuning.com/C...rt_p/c7-ca.htm
Former Vendor
Looking at the video, it appears the C7 used did not have the flexible air dam in place. I have the base C7 with a full width air dam. Will the air dam interfere with the curb alert installation?
Former Vendor
No, the air dam will no interfere with the curb alert. The curb alert mounts in front of those. This c7 had it removed for testing front splitters, not because of the curb alert.
Received 3,291 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
How would this mount with a front splitter on the car? No way could it be mounted below that as it would be way too low.
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
At 4:15 of the installation video above it mentions that the curb alert device automatically turns on/off sensing at least 13.2v. Would that mean when installed on a C7 with the optional CTEK charger (or other trickle chargers) it would result in the curb alert being cycled on and off depending on the charging cycle status?
http://www.ctek.com/int/en/page/whyc...-functionality
Former Vendor
do you ship to Canada?
Former Vendor
Former Vendor
Just installed mine today. It's well designed and everything you need other than a couple of basic tools is provided. The installation video listed in the original post is great.
As an engineer, I can appreciate the amount of design work and planning that went into this device.
Former Vendor
Former Vendor
