ACS splitter only?
ACS splitter only?
Aloha all,
Noticed a lot of folks running both splitter & rocker panel extensions or simply rocker extensions alone. Anyone running just the ACS front splitter? Pics maybe???
TIA & Mahalo
Boomah
TIA & Mahalo
Boomah
Received 4,683 Likes
Once the GM version becomes available, I'll most likely get one of those, without the side skirts. Unlike all the others made by aftermarket manufacturers, the GM version is a soft, semi-flexible material.
flexible would be nice... a curb ate my ACS this afternoon... I have the curb alert on the car as well... I guess I need to adjust it better.
Former Vendor
You'll notice, true AeroPackages are made of a rigid material to be efficient at high speeds. The Z06 splitter is made of a composite rigid material, whereas the Atlantic and Pacific editions are indeed made in a plastic injection material (softer) ... depends if you are looking for a purely cosmetic part or a combination of performance and efficiency.
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
GM 2015 version for the Atlantic Edition has Canards on the side too...
I most likely will do the same, but add the side skirts too... Nothing wrong with just using the splitter, but personally I think the skirts add more to the overall effect of the car.
I did notice the splitters on the Z06 are different, Carbon Fiber and much lower..with much more aggressive canards.....
