Black C7 with ACS Zero 7 Side Skirts
I like these the best out of all the ones available.
we mounted them using the three existing bolts up front, the two existing bolts in the back and Scotch Permanent Outdoor Mounting Tape ...
process.. clean with Dawn, clean with 50/50 water alcohol mix.
apply approx 2 foot strip of the tape to the flush section
peel about four inches of the release tape so you have access to it when mounting
hand tighten front and back screws so the side skirt is loose..
pull release tape off completely
press straight up on the skirt underside so tape has good adhesion
tighten the bolts
car will never be tracked - and they are very solid with no extra holes drilled into the car - that was important to me...
tighten the bolts
Looks great.
I've got a request for ya
could you please show a close up pic of where the splash guard meets the leading edge of the skirt? How far out from the side of the car does the side skirt come out?
Thanks in advance
Thanks in advance
Something does not look right there, on most I have seen (and on my SCP Stage 1's) the "skirt" should begin where the mudguard stops so it is one continuation there seems to be about an inch gap there...you cool with that ??
