Decoding a 2015 C7 VIN
Moderator
C7 VINs include a code that indicates trim level, transmission and Z51/non-Z51 or Z06:
2015 VIN Decoding:
This is an example of a VIN # for a 2015 Corvette Coupe (3LT, Z51, MN7):
1 G 1 Y L 2 D 7 X F 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
01. "1"= Built in US
02. "G"= General Motors
03. "1"= Chevrolet
04. Denotes the car line: Corvette is a "Y" body.
05. Provides more info about the car:
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. N=Z06 1LZ M/T
.. P=Z06 1LZ A/T
.. R=Z06 2LZ M/T
.. S=Z06 2LZ A/T
.. T=Z06 3LZ M/T
.. U=Z06 3LZ A/T
.. 9=export (Non US, Non Canada)
06. Body style: "2" = Coupe, "3" = Convertible
07. Restraint code: D – AJ7 Active Manual Belts, Airbags – Driver & Passenger and Seat Side
08. Engine: LT1 = "7", LT4 = "6"
09. Check Digit – 0 to 9 or X
10. Model year: F (2015)
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr. Z06s will start with #600001
2015 VIN Decoding:
03. "1"= Chevrolet
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. N=Z06 1LZ M/T
.. P=Z06 1LZ A/T
.. R=Z06 2LZ M/T
.. S=Z06 2LZ A/T
.. T=Z06 3LZ M/T
.. U=Z06 3LZ A/T
Received 19,289 Likes
'20-'21-'22-'23-'24
Thanks for the info.
2015 VIN's
You made a post quite a while ago. I'm in the D/FW metro area. We just sold out 2014 Z51 'vert' and are buying a 2015 Z06 automatic 'vert' that is claimed by GM to be a 'pre-production' 2015. It was built in November 2014 before the 'vert' automatics were released and the number is F5500071. Does that make sense to you???
They typically have unique numbers for the pre=production cars. This one seems by the documentation to have been used by Mary Bara (GM's president).
Does the number (55) make sense???
Moderator
<p>
</p><p>The first 5 indicates the plant - Bowling Green. The second 5 would normally be a 6 for a Z06. So, yes this is probably a pre-production car.</p><p> </p>
You made a post quite a while ago. I'm in the D/FW metro area. We just sold out 2014 Z51 'vert' and are buying a 2015 Z06 automatic 'vert' that is claimed by GM to be a 'pre-production' 2015. It was built in November 2014 before the 'vert' automatics were released and the number is F5500071. Does that make sense to you???</p><p> </p><p>They typically have unique numbers for the pre=production cars. This one seems by the documentation to have been used by Mary Bara (GM's president).</p><p> </p><p>Does the number (55) make sense???
