2014 vs 2015
1. 10th digit of the VIN indicates model year.
2. If the car is Cyber Gray or Lime Rock Green it is a 2014
3. If the car is Shark Gray or the new Orange, it is a 2015
That's all I've got for a no-options car.
Read that something to do with the display on the dash and you can not do a flash to update the 14.
So it sounds like you found a 2014 and are thinking about it. Get at least 20% off other wise not worth it. Can get supplier price (about 9%), 2014 depreciation at least additional 10-15% depending, so you can see might be best to get 2015.
6-speed auto = 2014
8-speed auto = 2015
Not sure how apparent this would be to the casual onlooker though.
Aside from that, just exterior colors and wheels are the most obvious visual indicators.
8-speed auto = 2015
Well there are some new color choice and rim choices. Also he 2014 has a nice depreciation factor at this point.
This ATX guy never seems to miss a chance to talk about how badly the 2014 C7 has depreciated. He must be seeing a lot better deals than I've seen.
Perhaps he's a potential used 2014 buyer that thinks the more he talks about a high depreciation rate the better chances the 2014 has of magically depreciating that much.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
All C7s will depreciate. Just like all C6s depreciate. The rate of depreciation of a '14 and a '15 will be pretty much the same.
If you buy one of the last '14s it will be a very low mileage car compared to most other 14s so will hold its value better.
If you buy one of the first 15s it will be a high mileage car compared to most other 15s so will lose more value in comparison.
I would offer that if resale value is high on the list of things you consider in buying a new Corvette, perhaps you should consider purchasing a different car.
And he's missing or ignoring some things, for example:
