Rear Brake Vents for a Vert?
I'm not going to address the question above in order to comply with the forum rule below. I've noticed a consistent amount of sarcasm in the member's posts and it's unfortunate because people come here to learn and ask questions. There is a real lack of tolerance and goodwill on here.
"Any thread(s) that contain open bickering, name calling, subtle derogatory messages, "digs," personal attacks, or anything negative in nature will be closed/edited or deleted, and any participating members who post in violation of this rule, will jeopardize their posting privileges."
Received 3,288 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
For the OP, I looked inside as my wife put the top down on my vert. The only place with room to put those vents is in the panel that covers the top when it's down. It also covers the top mechanism and would drain water into the trunk. So, if you want those vents, and they would fit there BTW, you'd either have to seal them or put some kind of ducting to drain the water out under the car.
The openings on the coupes rear fender tops are air intakes, not vents. Same for the openings on the lower rear fenders just ahead of the wheel wells on the Z06. The openings on the hood, front fenders, and rear fascia are vents (where air exits).
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,813 Likes
2015 C7 of the Year Finalist
I don't think the OP is expecting functional vents/intakes on the cowl. HE simply wishes to have the aesthetic look of the vent/intake to replicate the look on the coupe. A non-functioning "vent/intake" that doesn't actually have a hole under it is what he's asking for. Just to break up the vast expanse of red and have a similar "look" of the coupe is his purpose. I could be wrong but I think that's what he's after.
Elmer
Elmer
Elmer
Elmer
I'm sure it could be done and look good, but it's not as simple as buying the black vent tops you see on coupes and sticking them on the car.
