BEWARE of B&B Exhaust PROBLEMS!!!
I had a new B&B PRT Exhaust System installed on my 2014 Stingray toward the end of January, shortly after getting the car and basically as soon as the Black Speedway Tipped System was available. My car is non-NPP and the exhaust was ordered as such. I am now on my 3rd system and still have a check engine light. I have tried everything so far and hoping someone might be able to shed some light on it for me…
The first system was installed at the end of January by a very trusted Corvette shop in our area. They noticed the Driver’s side valve was clocked incorrectly on the pipe resulting in it hitting the rear differential cooler line fitting. This led to the entire system having to sit further back which then led to the tips not lining up and looking very awkward. Like I mentioned before they are Speedway tips so having them perfectly straight is important.
B&B replaced this system under warranty, had the new one installed at the shop who took care of the installation free of charge. They again had to do some extra work to get the tips to line up perfectly, which they did and the car looked great.
Didn’t drive the car much as it was February/March here in PA and not so Corvette friendly. Car sat in my garage waiting for nicer weather.
April rolls around, I had the car out and a Check Engine light came on… Not knowing what it was I brought it to the dealer who diagnosed it as the Pass Side Exhaust Valve Actuator not functioning properly. After a $408.10 bill they cleared the code and sent me on my way. Code came right back so I brought it back to my exhaust installer. They then contacted B&B who knew about the problem and recommended we install washers under the actuator mount points to shim it properly for possible binding issue.
They shimmed it, that didn’t work, B&B then sent out their fabricated shims which they had from the same issue before and they installed, again, no go. Multiple codes pop right back up.
P26C8
P12F0
P12FE
P12FD
P12F1
Clear Codes
Following Codes remain after second start-up
P26C8
P12F1
P12FE
My installer checked the valve manually and could tell it was bound-up compared to the other side. These are B&B’s valves welded into their system. Now, my installer has B&B send out yet another full system and goes out and buys a new GM actuator, worried that after it has been trying to open and close the bound-up valve it may have done damage and is resulting in some of these codes. Figured it would be better to be safe than sorry. So they install ANOTHER new B&B system on my car free of charge and replace the actuator along with it at their expense. Check the valve operation, all smooth this time. Upon second start up, same codes appear;
P26C8 and P12F0
We learn of the new GM exhaust actuator relearn procedure, I take it to the Chevy dealership, have them perform the procedure hoping these codes are from the new actuator, but once again, both codes come back.
I don’t know what else to do. B&B is saying they don’t have anyone else with this issue and my installer now has an enormous amount of time and money tied up in trying to sort this out for me. I have a ton of time, money and headaches into this and still have a brand new car with a Check Engine Light.
Anyone have any ideas?
P26C8
P12F0
P12FE
P12FD
P12F1
Clear Codes
P26C8
P12F1
P12FE
P26C8 and P12F0
Crap, B&B is my preferred system after having on both BMWs. LOVE the sound.
Sounds like other than the Chevy dealer most of the extra expense has been taken car of, however, you have a lot of anguish and running around in support of all of this to get resolved. Seems like a lot of effort to get it straightened out.
Sorry to hear about it. Hoping you get a resolution for you and the rest of us looking forward to a B&B system.
another reason to stick with Corsa
OP - I'd suggest letting B&B know that you are taking their system off and want a refund w/costs for your shop.
On your side of things I'd suggest putting everything back to stock and making sure everything is working OK with a stock setup.
This is the problem with the aftermarket. Most suppliers have no tolerancing, and no quality control. I would be surprised if they even have full engineering drawings. I ran into this with another vendor years back. There were no two pipes the same. I think I went through four sets, and cherry picked ones I could shim to fit. Even bigger companies like Walker will ship stuff to the aftermarket that they would not dare ship to an OEM. I gave up on aftermarket exhaust systems after those experiences.
Michael
Michael
Michael
Michael
I had no idea that putting aftermarket on non NPP there would be A problem.
I guess whoever I purchase the B&B from I'm going A have to make them guarantee the pipes and the labor. Thanks TVOT for letting us know.
Let us know how you finally make out.
GZire's above comment about putting everything back to stock sounds like the most viable solution at this point. What a terrible expense to go through though.
It does sound like the problem with throwing codes is coming from the AFM exhaust valves located before the mufflers? And these valves came with the BB aftermarket system? Are they different valves than stock, that are BB's own design?
Corsa's solution to these valves seems to be to just leave them in place and cut the pipe after the valves, but before the mufflers to install their system.
I was very happy with the Borla S-type II on my C6, so my intention was to install the same on my non-NPP C7. Unfortunately, Borla doesn't have the S-type II for the C7 yet. At least 2 months away, according to the Borla rep I spoke to this morning.
So my next choice was gonna be the B&B PRT until I read this post. So far, no happy ending (sorry) but I'm hoping to hear of a successful resolution soon.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Michael
Michael
As posted by others, I'd try and get back the cost(s) for yourself and your installer. The installer has surely gone the extra mile and even tho they may not be a vendor here, you could at least mention the name of the shop because they deserve kudos imo.
You have my sympathy. The problem as I see it is that when you start modifying you become your own development engineer. As others have noted above, even the best aftermarket supplier doesn't have the engineering and testing resources of a company such as GM. I don't know any GM engineers currently, but I do know some from Chrysler, and the level of subtlety and knowledge and attention to detail that they bring to product development is pretty amazing.
I used to do simple mods on my own when younger to most cars that I owned. (You haven't lived until you have installed an aftermarket cruise control system into a manual transmission 1979 Dodge Omni, my first little project ever. It took months to make it work even close to acceptably, and any big bump would still make it kick off.)
Problem was, I always did one mod too many. That is, I always kept doing things until I did one that just could not be made to work properly. (Computer control on current vehicles has probably made this even worse, as witness your repeated codes.)
Now, I wouldn't even PlastiDip an emblem.
Good luck, and again, you have my sympathy.
Ok, thanks for the heads up. Prior to reading your post I ordered the B&B Fusion exhaust earlier today that works with my c7's dual mode factory setup. I'm considering canceling the order ASAP but please be honest here, did you do headers & cats as well or any other mods that may have contributed to your troubles.
Please state all the facts so everyone can make a fair assessment as to wether or not they want to partake in a B&B exhaust system for their c7. Thanks
