NPP Exhaust Question...
Old 07-13-2014, 05:36 PM
freebird
freebird's Avatar
Default NPP Exhaust Question...
Since there is no Mild2Wild for the C7, how can you keep the flaps open. Love the sound when they are open full time..
freebird is offline
Old 07-13-2014, 05:40 PM
vettnutt
vettnutt's Avatar
It is controlled in the touchscreen menu settings. Set it to the driving mode you are in or open most of the time.
vettnutt is offline
Old 07-13-2014, 05:41 PM
mkr1966
mkr1966's Avatar
Set to off on setting screen and pull fuse 41(yellow one).
mkr1966 is offline
Old 07-13-2014, 05:42 PM
Sin City
Sin City's Avatar
Received 4,116 Likes on 1,470 Posts
2020 C8 of the Year Finalist - Unmodified
I wish this button were on the main screen. It's dangerous to go so deeply into the touch screen menu's to switch it while you're driving.
Why not just have one button on the main screen "NPP On/ Off" to hit? Seems so obvious.
Sin City is offline
Old 07-13-2014, 05:43 PM
AFVETTE
AFVETTE's Avatar
Correct me if I'm wrong when ever the car drops into the V4 aka AFM mode the exhaust valves close.
So you'd need to install a "tune" to disable AFM from happening? Right????
AFVETTE is offline
Old 07-13-2014, 05:47 PM
mkr1966
mkr1966's Avatar
On the M7, leave out of eco and AFM never works. Auto I think your screwed.
mkr1966 is offline
Old 07-13-2014, 06:26 PM
Bigdog9586
Bigdog9586's Avatar
Not enough room on screen for all our wants.
Bigdog9586 is offline
Old 07-13-2014, 06:28 PM
Sin City
Sin City's Avatar
This is what bugs me about software people (and I work with a lot of them).
They like to think they know everything so "choice" is not an option.
"Why should anyone want to change it? It's perfect the way I designed it!"
Sin City is offline
Old 07-13-2014, 06:42 PM
SASprof
Support Corvetteforum!
SASprof's Avatar
Agreed. That's why I'm going aftermarket. Clean and simple. No entanglement with car's software, electronics.
SASprof is offline
Old 07-13-2014, 07:42 PM
millpond
millpond's Avatar
For the auto, use sport or track, and the manual trans mode and you are good to go.
millpond is offline
Old 07-13-2014, 09:47 PM
stingraymyway
stingraymyway's Avatar
Location: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
stingraymyway is offline
Old 07-13-2014, 09:50 PM
Theta
Theta's Avatar
St. Jude Donor '14-'15
This is the correct answer. ^
Pull fuse 41, flaps never close.
Theta is offline
Old 07-13-2014, 10:33 PM
Klyde
Klyde's Avatar
You can force the two muffler valve to stay open all the time by setting the correct menu item but that still leaves you with the AFM valves. Two of the flaps are for setting the correct back pressure for four cylinder mode. I personally like getting 33 mpg on the highway trips so I'm not pulling any fuses or using aftermarket exhaust. If you have an automatic you want to keep the exhaust stock of else throw away your warranty and get Active Fuel Management tuned out because AFM is active in all modes and needs the two valves before the mufflers to work right. Not sure about damaging the motor, but the potential to do so is there and I'm sure it will screw up your fuel mixture without the correct back pressure. The two AFM valves are on every C7 made even if you don't have NPP.
Klyde is offline
Old 07-13-2014, 10:41 PM
Theta
Theta's Avatar
Fuse 41 only affects the rearmost flaps, which attenuate sound (NPP - the topic of this thread).
Fuse 32 controls AFM, which the OP was not asking about.
Lastly, the AFM valves are not used for backpressure - the CCM controls these in V4 for (again) additional sound attenuation.
Theta is offline
Old 07-13-2014, 10:44 PM
Theta
Theta's Avatar
Additionally, contrary to your belief, the NPP valves will not remain open at all times even with Engine Sound Management turned off.
The only method of leaving these open is removing fuse 41, which is perfectly safe for the vehicle.
Theta is offline
Old 07-13-2014, 10:49 PM
Klyde
Klyde's Avatar
I watched a video of one of the engineers that designed the AFM system and he stated it was for correct back pressure in four cylinder mode not sound control. He said it was tricky getting everything just right for eight cylinders and also work with only four. The air flow through the system is quite different between the two and is addressed by the AFM valves. There is no need to remove only the fuse for the NPP because you can turn it off in the menu. If you hear a sound difference when NPP is turned off it is the AFM valves doing it. Any one considering getting after market exhaust because they didn't buy the NPP will still have to consider the AFM valves to make the car work correctly. The AFM valves are not for sound control but to tune the exhaust for four cylinder operation.
Theta:
You can do what ever you want to your own car but be careful what you tell others because there is a real chance of screwing up their cars by taking out certain pieces of a very complicated system. I'm just trying to give them as much information as possible so they can make an educated decision about this modification.
Klyde is offline
Old 07-13-2014, 10:59 PM
Theta
Theta's Avatar
This is enough to make me pass over your post.
If you're interested in learning instead of pushing incorrect data, refer to the Fuse 41 thread. If you still want to argue, I'll pull the factory electrical schematic sheets that show the tip-in and mode closure.
But hey, what do I know, right?
Theta is offline
To NPP Exhaust Question...
Old 07-13-2014, 11:02 PM
Klyde
Klyde's Avatar
You can pass over all of my post if you want. It's not you I'm trying to show here. I'm stating that the rear valves are deactivated by the menu and you don't have to remove any fuses. There is no reason to pull that fuse. You may if you want to but the NPP valves are turned off by the menu. If you here a sound level change after turning it off in the menu then you are hearing the AFM valves activating.
Klyde is offline
Old 07-13-2014, 11:03 PM
Theta
Theta's Avatar
Theta:
Hey bud, if you haven't noticed, I know a thing or two around here... Sort of goes with the territory.
I respect your opinion, but you're wrong.
See this thread:
http://forums.corvetteforum.com/c7-t...ck-result.html
Now you could apologize, or just act like every other *** on this forum that wants to be right. They don't let me post incorrect information just for the hell of it around here...
Theta is offline
Theta
Theta's Avatar
Incorrect. See above... You just don't realize that you're wrong. You still are, but you'd still rather fight than learn.
Read the thread, and then either come back and argue more, or apologize. If you do choose to argue, I'd love to see your explanation of the sound difference for all of us without AFM enabled.
Theta is offline
Quick Reply: NPP Exhaust Question...
