Goofy Dip Stick?
Goofy Dip Stick?
I know the answer to all questions can be found here!
So, here goes. C7, Car #24302, non Z51, Auto, 3100 miles. When checking my oil level I am mystified as to the actual amount of oli in the crankcase because one side of the graduated weight reads Full and the other side reads 1/3 Full -
Yes the dip stick is fully in the tube and the car is level in the garage so why do I get two drastically different readings from the same goofy dip stick?
And, if this is by design do I now average the readings, use one side and ignore the other, or say the hell with it and let it run dry..
Your sage advise is welcome..
If you rotate the dipstick, you are just making it read the highest level all the way around so you might as well just read the high side of the stick.
The true level would be half way between the high and low readings.
Not sure why GM made the stick go in the crankcase at such a steep angle.
GM dipsticks have frustrated me for years! The dipstick on my old C5 was ridiculous, the level would always show completely full, so I would think I wasn't burning oil but when I drained it at oil change time I would measure what came out and find that it was down a quart. So I just stopped using the dipstick completely and would just top it up based on mileage (I knew the car used about a quart every 6000 miles so I'd just add about 1/4 qt every 1500 or so) Lucky for me, my C6 only uses about 1/10th of a quart of oil every 2000 miles, so I really don't need to check the dipstick at all, I'll just continue to measure how much comes out at oil change time so I know how much oil needs to be added in the future.
