Valentine Radar Detector Savvy Option
I have read a lot of readers chat about the difficulty installing radar detectors.
Valentine offers an option for its detectors called "Savvy".
This option plugs directly OBD port under the dash of all vehicles produced fron 1996 to present.
This option not only let's you have a keyed power supply, but you have a dial to adjust the speed that the detector kicks in full alert. It still works below the set speed but acts when an alert is sensed as if you instantly hit the mute button.
If you order with a new Valentine Radar Detector the cost is $49. extra. If you forget to like I did, it is $69.+ freight of $9.95.
Great option to make install easy. Just run wire up windshield molding and to spot you want to mount. 15 minutes maximum.
Can we please get a pic of the set up I currently have a Cobra XRS9570 but was thinking of upgrading to the v1 since people have been saying that theyve had the same unit for 10-15 years and it still works great and the only reason I bought the cobra was basic detection and it was cheap and in the recommended products during an amazon purchase .
Wanted to see the best setup for when I get my c7
www.valentine1.com
My V-1 is old but I bought the Savvy for the C7 in September. Installation couldn't be easier, it works great. A couple quirks are non-issues:
1) when you open a door or trunk the V-1 powers up but it times out; car can sit a month and the battery is still up.
2) with the Savvy plugged into the ALDL port OnStar cannot remotely read your tire pressures and certain other data...but who cares about that?
Jukebox Graduate
Just go to there web sight and look up the option Savvy
www.valentine1.com
www.valentine1.com
I installed the Savvy last week and it works well with the aforementioned quirks. Beat the heck out of tearing apart the trim to run wires and the low speed mute works quite well.
Well worth the cost IMHO.
Sorry No Pics
As said in a previous thread, the Onstar service reporting which is pooled once a month will not report some items such as tire pressure.
This all happens automatically when you start the car the first time.
Is the cord that comes with it long enough that you can mount the actual V1 anywhere? could you use a blendmount and run the wire along the headliner and down to the OBD port?
Yes... I believe the cord that comes with it is either a 7ft or 8ft cord and it's long enough to make it up through the roof liner... over to the for pillar.... and down to the port. I have this set up and it took me about 10min to do. Much better than running wires all the way to the back of the trunk. Another forum member had pics of his setup a while back. If you do a search I'm sure you can find it. I will take some pics of mine later on
By the way the Savvy option as far as I know is for the Valentine only,
Doesn't this make it a 'no-brainer' for a radar install? Why go through all the trouble of removing all the trim and tapping into an alternative source? This seems like a great way to go and the detector (from what I read) is one of the best. Hmm.
I'll echo other responses here. I have the v1 with a blendmount and the Savvy. Works great and very easy to install. I also can't imagine why people tear apart the dash to install their V1. The ability to change the speed sensor to different auto mute speeds is very convenient.
My installer installed my passport max and wired it to the homelink in the rear view mirror. It does power up when you open the door or trunk but turns off after a few minutes. Was an easy install and he didn't have to go all the way to the back or remove any dash parts. Doesn't effect any of the systems in the car at all.
Installed pics
For reference, here are some installed pics of the Valentine One head unit on a Blendmount holder, the SAVVY plugged into the OBD, and the remote unit velcroed to the dash. Honestly, there's not much to see... It's pretty clean and easy. You can do it all yourself. The only extra tool that will help you is a plastic pry/push tool to shove the cord under the very stiff trim around the windshield. I bought a cheapo E-Prance kit from Amazon, which does the job nicely:
I experimented with putting the remote unit on the left of the steering wheel, just under the trunk release switch. I kept hitting my knee on it when I got in and out of the car, so I moved it to the right of the wheel. I can spot the display through the steering wheel and it's easier to press the mute button. The remote unit is not at all necessary for operation. I find it easier than reaching up to the rearview mirror to mute the alarm and it makes the display lights less intrusive in your field of vision.
HEAD UNIT ON THE BLENDMOUNT, ATTACHED BELOW REARVIEW MIRROR
SAVVY UNIT PLUGGED INTO OBD PORT (please excuse dirt on floor!)
REMOTE UNIT GLUED TO DASH
For reference, here are some installed pics of the Valentine One head unit on a Blendmount holder, the SAVVY plugged into the OBD, and the remote unit velcroed to the dash. Honestly, there's not much to see... It's pretty clean and easy. You can do it all yourself. The only extra tool that will help you is a plastic pry/push tool to shove the cord under the very stiff trim around the windshield. I bought a cheapo E-Prance kit from Amazon, which does the job nicely: http://www.amazon.com/gp/product/B00D7XNQHG
Do you live in an area that radar dectors are against the law
Thanks Ken thats exactly what I was looking for, wanted a complete idiot proof method of routing every wire because ive never done something like this, my cobra setup was basically connect wire to power and stick it on the center of the dash with the wire just hanging there lol
