Soot on exhaust pipes
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I wasn't wondering how to clean them or the best polish. My question is why is there soot on the pipes. I never had this problem before on my Grand Sport. Just wondering if it is a PVC problem because of Direct engine.
Naples FL
My car has 11k miles & is in sport 100% ...my tips are always clean....even after long trips...(500+ miles) I have noticed though, on other c7's the outside tips are always black... I figured they were not in sport! Not sure why this is ...
Not really normal with Top Tier Gas. You should check your oil and don't remove the soot. Drop by the Dealer and have the Corvette guy look at it before cleaning. I would also call Cust service and have it documented on your VIN.
(cut open a muffler sometime and notice how much "soot" lines the interior)
Are the gates ALWAYS open in sport mode? I have the engine (sound?) management setting set to "off" so my NPP always remains open regardless of the selected driving mode. I regularly get heavy soot in my 2 outside pipes as well.
Actually, setting it to OFF still doesn't keep them open 100% of the time. They will still close...
Woodbutcher58 (04-09-2022)
22 Hypersonic Grey HTC
Soot on outer NPP tailpipes
I always use Shell 93 octane gasoline and I still get soot on outer NPP tailpipes, even after one drive. What am I looking for when I check the oil (besides if it's at the correct level)?
Naples FL
I have my engine sound management set to "on" . I believe they are open at start up and most local driving.. They close on the highway except when driven briskly .... I only use Shell 93.
