Help with driving modes on C7 Z51 with MSR
I have a C7 Z51 with MSR. My 2008 C6 I'd put in competitive driving mode when I wanted to slide the rear end a little....let it loose a little. I'm not sure what the mode I should be using in the current array of different modes would be. You can use sport mode and take the traction control off with the touch of a button or go into one of the 5 different track modes but I'm not really sure which one to use as the wet mode and I believe even the dry mode won't let you really swing the rear out with the throttle. Just trying to get a better understanding of how these modes work because the manual isn't really that clear on this.
