Strange sound while warming up.
Old 07-08-2014, 10:35 AM
WKMCD
WKMCD's Avatar
Default Strange sound while warming up.
I have a Z51 A6 3LT car. When I start it up and for the next few minutes I get a humming/droning sound. It's almost like diode noise but lower in frequency. It sound like its coming from the right side of the car in front of the passenger seat. I don't know if you can hear it outside the car but you definitely can inside. It seems to go away once the car is warmed up for a couple of minutes.
Anyone else have this?
Old 07-08-2014, 10:43 AM
MikeyTX
Support Corvetteforum!
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Have you checked ...........
The feeding tray for the mice must be empty. The humming/droning sound you hear is the surviving mice praying over their deceased . . . . . .
Old 07-08-2014, 10:45 AM
WKMCD
WKMCD's Avatar
That was helpful...
Old 07-08-2014, 10:49 AM
Al Engel
Al Engel's Avatar
Yep - I have same sound - - I believe it is the electric 'air pump' to supply extra air for the cats to heat up quicker. Once the cats have 'lit', the air pump shuts down - no more 'whine', and everybody is 'happy'. This is what I 'believe'... but I'm sure others will have additional wisedom on this subject.
Old 07-08-2014, 10:55 AM
socaljet
socaljet's Avatar
I wondered about that and guessed it was coming from a cold torque converter. It seems more pronounced on cooler days to the but only lasts for a quarter mile or so.
WKMCD
WKMCD's Avatar
That's exactly what I thought it might be. Thanks!
Old 07-08-2014, 11:23 AM
slief
slief's Avatar
All of the above or is your AC on when you're warming the car up? Could be the compressor you are hearing while the car is at idle.
Old 07-08-2014, 11:27 AM
WKMCD
WKMCD's Avatar
I turned everything off but the engine and it still made the noise. I think it is the air pump. Just to confirm, does anyone know where the air pump lives in a C7?
Old 07-08-2014, 12:17 PM
Modshack
Modshack's Avatar
It is...
Old 07-08-2014, 12:44 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
I'm curious.. WTF is a "diode noise"?
Old 07-08-2014, 01:58 PM
WKMCD
WKMCD's Avatar
Ken,
I'm sure you can make me smarter but this is from the C5 service manual.
According to FSM noise problem could be:
1. loose drive pulley
2. loose mounting bolts/screws
3. worn or dirty bearings
4. faulty diode or faulty stator
I had a similar noise in my C5 and it turned out to be a faulty diode in the voltage regulator/alternator. That's why I described the sound as such.
Kevin
Old 07-08-2014, 03:09 PM
KenHorse
KenHorse's Avatar
Ken,
Kevin
Alternator whine, gotcha
Old 07-08-2014, 03:21 PM
MikeyTX
MikeyTX's Avatar
NCM Lifetime Member
That was helpful...
Always glad to lend a helping hand.
Old 07-08-2014, 03:25 PM
BRCC
BRCC's Avatar
For what it's worth I have the same car configuration and the same sound. I believe the answers above are correct. Being I had a new engine put in a few weeks back did not recall that sound before and actually recorded it on the iPhone and was going to ask the service manager if he knew what it was. However, now no need being it is common. Thanks forum members.
Old 07-08-2014, 06:56 PM
BRCC
BRCC's Avatar
Also saw a Techlink bulletin that in another model (Not Corvette) there was an exact description of the sound that was related to the Brake Booster pump which last around 20 seconds. So it could be a little longer in the Vette.
To Strange sound while warming up.
Quick Reply: Strange sound while warming up.
