Help-wrong jacking point
Jacked up c7 to put on GM mud flaps. I jacked rear with 4 wheel big plate floor jack J standed it. Showed my son big cross member in front, but he went in between both aluminum cross members on the black channel. Now it bent touching bottom of engine. Can I use a crow bar against big cradle to bend it back, should i leave it, what is it for? Or Em I up a sh@ts creek with out a paddle. Hey guys give me your best educated shot! Thanks I added an attachment, I hope if not I will post again it about one man's opinion about oil.
I think we need a picture. I found these two, but I don't see a black channel that could be bent to touch the engine.
In the absence of more info, I'd agree that it needs to be taken to the dealer on a roll-back to prevent further damage.
Concur
If its where that yellow arrow is pointing I wouldn't chance it. Have it flat bedded to the dealer. I didn't have to jack mine up to put all the flaps on. Took 20 minutes tops to do. dpb
E-Ray, 3LZ, ZER, LIFT
Received 9,646 Likes
man that sucks , drive it slowly and see if you can tell any thing, different, I didn't buy a jack puck so I used a steel 1/4 cup from the kitchen... worked great... also take it to DEALER ASAP ,BUT NOT SURE YOU NEED IT TOWED... GOOD LUCK
Yea that is it, where the yellow arrow is pointing. I did not want to go in detail but I Klasse sealed the rims and the calipers. I live on a dirt road and power rinse and spotless rinse for $1.25 works as long as you go 70 mph immediately. Spent $1500 having the nose, hood, rockers, back fender and mirrors wrapped in Xpel the guy is a surgeon.
Was also wondering what the black channel was that you refered to as there is none! If the pics put up with the yellow arrow are what you are referring to, that is the composite spring! It’s not a channel. Don’t know what happens when you jack up in the center of the spring! If it is truly "bent," you broke the spring! It needs to be replaced! Dealer job, curious how much it will cost.
Yeah OP your son broke the composite spring.... DO NOT DRIVE THE CAR. Flat bed it to the dealer and break out the wallet.
They're not terribly hard to change DIY if you're half competent working on cars.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Thinking there's a need to jack up the car in order to do the mudflap thing and then allowing his son to jack up the car using the transverse spring as the jacking point pretty much answers that I'm afraid.....
I wasn't going to say it directly... but it's why my first recommendation was to flat bed it and break out the wallet
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
Mud flaps on a corvette, says it all............
Next is the old granpa, curb alert system............. cause I can't drive.
How about a nice Cadillac instead.
Boom, Confetti!
I knew I would be burned, but read my last post it was a tire rim detail, but I keep hearing about my mud flap thing. I will come back with other things the are meaning to this web sight, I promise. I am not on any social media what so ever, no time, never will. I will give all a little kiss to all the high brows, my car was tagged "of special interest" so I have perfect fit and no orange peel. The total frame of the 2014 c7 sits in my building. I have learned alot and I owe knowledge back. Hey give me a man hug, only a Harley gets more tail!
St. Jude Donor '14-'15
Guys, there is a DIY on proper lifting of the car located here:
http://forums.corvetteforum.com/c7-t...fications.html
Also, Jesus Christ... take that picture down with the yellow arrow. You can't put weight on the inverse leafspring as you now know...
I hope nobody else does this in the future, as there is all of the needed information sitting here on the forums...
