It's Official '15 Z06 at 650HP
Old 06-06-2014, 07:07 AM
Al Engel
Al Engel's Avatar
Default It's Official '15 Z06 at 650HP
The following is from today's AutoBlog....
2015 Corvette Z06 Rated at 650 Horsepower
Supercharged LT4 V-8 engine is the most powerful ever from Chevrolet
DETROIT – The all-new 2015 Corvette Z06 is the most powerful production car ever from General Motors and one of a few production cars available in the United States that delivers more than 600 horsepower.
The Z06's LT4 supercharged 6.2L V-8 engine is SAE-certified at 650 horsepower (485 kW) at 6,400 rpm and 650 lb-ft of torque (881 Nm) at 3,600 rpm.
"The LT4 Small Block sets a new benchmark for power and torque at GM," said Steve Kiefer, vice president, GM Powertrain Engineering. "The engine also puts the new Corvette Z06 on par with the most powerful supercars offered in America, while delivering performance with impeccable manners that make it suitable for daily driving."
Compared with other supercar engines, the LT4 is a veritable fountain of low-end torque, producing 457 lb-ft (619 Nm) just off idle and 625 lb-ft (847 Nm) by only 2,800 rpm. The V-12-powered Ferrari F12 Berlinetta, for example, produces about 28 percent less torque than the Z06, despite offering about 12 percent more horsepower – and its peak torque isn't achieved until 6,000 rpm. The LT4 maintains 90 percent of its peak torque, or 592 lb-ft (802 Nm), from 2,500 to 5,400 rpm.
The new LT4 engine eclipses the Porsche 911 Turbo S engine's peak power levels by 90 horsepower (67 kW) and 134 lb-ft of torque (182 Nm).
"Torque is the pulling power of an engine and the LT4's abundance of it at every rpm in the engine's speed range helps the 2015 Corvette Z06 accelerate quicker and respond nearly instantaneously," said Jordan Lee, chief engineer for Small Block engines. "It's the very definition of power on demand."
The new Z06 engine produces 40 percent more peak torque (180 lb-ft / 244 Nm) than the previous-generation's 7.0L LS7 engine – and 7.5 percent more than the supercharged 2013 Corvette ZR1's 604 lb-ft (819 Nm). At 3,200 rpm, the new LT4 surpasses the LS7 by 208 lb-ft of torque (252 Nm). On the horsepower side of the graph, the LT4's 650-hp rating is 29 percent greater than the LS7's 505 horsepower (376 kW), and 12 horses more than the ZR1's LS9 engine.
"The new LT4 engine builds on the design strengths of our previous supercharged engine and leverages the technologies introduced on the Corvette Stingray – direct injection, cylinder deactivation and continuously variable valve timing – to take Corvette performance to an all-new plateau," said Lee. "Our new, very compact supercharger also helps the engine make power more quickly, and perhaps more importantly, it helps produce more torque earlier in the rpm band."
"It's also worth mentioning that the LT4's supercar performance numbers are achieved with an engine that is nearly the same size as the very compact LT1 engine introduced in the 2014 Corvette Stingray," Lee said. "The power density of the LT4 makes it one of the smallest and lightest 650-hp engines in the industry."
LT4 details
The new LT4 engine is based on the same Gen 5 small block foundation as the Corvette Stingray's LT1 6.2L naturally aspirated engine, incorporating several unique features designed to support its higher output and the greater cylinder pressures created by forced induction, including:
• Rotocast A356T6 aluminum cylinder heads that are stronger and handle heat better than conventional aluminum heads
• Lightweight titanium intake valves
• Machined, forged powder metal steel connecting rods for reduced reciprocating mass
• High 10.0:1 compression ratio – for a forced-induction engine – enhances performance and efficiency and is enabled by direct injection
• Forged aluminum pistons with unique, stronger structure to ensure strength under high cylinder pressures
• Stainless steel exhaust manifolds and an aluminum balancer that are lighter than their LT1 counterparts
• Standard dry-sump oiling system with a dual-pressure-control oil pump.
A new 1.7L supercharger spins at up to 20,000 rpm – 5,000 rpm more than the supercharger on the Corvette ZR1's engine. The rotors are smaller in diameter, which contributes to their higher-rpm capability – and enables them to produce power-enhancing boost earlier in the rpm band. That boost is achieved more efficiently via a more direct discharge port that creates less turbulence, reducing heat and speeding airflow into the engine.
"The Small Block's cam-in-block design heritage has always enabled very high performance and responsiveness in a small, compact package – an attribute amplified by the performance of our new supercharger's design," said Lee.
The LT4 is assembled at the new Performance Build Center at GM's Bowling Green Assembly Plant and at GM's Tonawanda engine plant in New York. It is matched with a standard seven-speed manual transmission or an all-new, paddle-shift eight-speed automatic transmission built in Toledo, Ohio.
Designed to deliver shift responses on par with the world's best dual-clutch transmissions, it is the first automatic offered in a Z06. It also makes the Z06 one of the few cars this powerful to offer the choice of a conventional manual transmission or an eight-speed automatic.
The 2015 Corvette Z06 goes on sale in early 2015.
Old 06-06-2014, 07:26 AM
bigblock427
bigblock427's Avatar
Received 1,347 Likes on 1,058 Posts
Awesome.
Old 06-06-2014, 07:38 AM
leadville1
leadville1's Avatar
I read in Motor Trend that the eventual ZR1 will have a factory twin turbo motor based on what is going into the CTS V, they are estimating 700-800 hp. Isn't that just getting into the silly range with this car?
Old 06-06-2014, 08:02 AM
cmicasa
cmicasa's Avatar
No.
It could in theory be an engine that could go into the upcoming Caddy Flagship.. not to mention.. if Cadillac and GM are thinking.. a CIEN type vehicle to go completely after Lamborghini or Bugatti.
GM has so much damn potential to make Cadillac and Corvette world killers it just isn't funny. And despite the negative comments of sell-out foreign car loving idiots I believe that they are effectively going in that direction.
JEEEEEEEEEEZUS... They done did it again
The Z06’s LT4 supercharged 6.2L V-8 engine is SAE-certified at 650 horsepower (485 kW) at 6,400 rpm and 650 lb-ft of torque (881 Nm) at 3,600 rpm
That will pull a HOUSE down the street and drop it off in front of a Ferrari.
Launch Control and proper tires better be ready, I'm thinking that launch times will be in the 2.8-3second range. Wow. If they were to even consider a ZR1 I shudder to think. It is also almost a given that the CTS-V will have at least 600HP.. and this engine could possibly end up in Omega.
Old 06-06-2014, 08:31 AM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
I just read the announcement and this is a true Supercar. I cannot wait ubtil it is re;eased and kits the street. I have a friend thta has already place an order well deposite.
Old 06-06-2014, 09:01 AM
Patriot77
Support Corvetteforum!
Patriot77's Avatar
Originally Posted by bigblock427
Awesome.
Your "Avatar" is also AWESOME!!!!!!!
Old 06-06-2014, 09:11 AM
fredl11
fredl11's Avatar
Yes but does it come with an ECO mode??? or just GET Go!
Old 06-06-2014, 09:16 AM
Bill17601
AIR FORCE VETERAN
Bill17601's Avatar
The price on used ZL1's just dropped.. Not the big dog anymore
Old 06-06-2014, 09:27 AM
sahowley
sahowley's Avatar
I'm saving for a 2016 ZO6!!!!! If it says under 100k the wive will be ok with it
Old 06-06-2014, 11:25 AM
09Z06pj
09Z06pj's Avatar
Received 1,100 Likes on 752 Posts
The ZL1 never was the "big dog."
Old 06-06-2014, 11:37 AM
air86
air86's Avatar
I am now predicting a power bump in the stingrays to about or over 500 in the upcoming years 2016-18 in that range. Just like the c6 going from the LS2 to the LS3. This does **** me off that the stingray only received a modest 30 hp bump with NPP, while the z gets an astounding 150
Old 06-06-2014, 06:46 PM
Bmbarney
Bmbarney's Avatar
Im #1 at my dealer for the ZO6, its with great regret that I will be giving up my StingRay that I already LOVE! But OMG, its starting over for me again ... I just cant wait!
When I was in Bowling Green a couple weeks ago, I had seen the ZO6 engine blocks and some people in the room working on engines through the windows.
Old 06-06-2014, 07:50 PM
Supersonic 427
Supersonic 427's Avatar
Received 1,649 Likes on 817 Posts
650/650 That is a lot of HP and Torque! That Z06 will be one hell of a Corvette!
Old 06-06-2014, 08:01 PM
69L79
69L79's Avatar
Location: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Home Run.
Old 06-06-2014, 08:14 PM
thedofuss
thedofuss's Avatar
whatever. dont you have to ask yourself as a shareholder of GM: is this really the best R&D focus? what is the marketing strategy here, for a company just emerging (they say) from bankruptcy? id love to read their 5-year plan.
Old 06-06-2014, 09:27 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Awesome news for sure
Old 06-06-2014, 09:41 PM
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,447 Likes on 2,272 Posts
I'm not a shareholder, but that said, I doubt GM will lose money on the Z06. If anything, its profit margin on the Z likely will be wider than on the Stingray.
To It's Official '15 Z06 at 650HP
Old 06-06-2014, 09:51 PM
leadville1
leadville1's Avatar
It seems to me you could put in the Edelbrock SC and have essentially the same package for a lot less.
85k for a base Z06 seems high to me.
Old 06-06-2014, 10:35 PM
C7 4 Me
C7 4 Me's Avatar
Whatever to shareholder considerations. I don't own any of their stock.
I do know, however, that they're actually making sports cars that interest younger guys again (something they need to do if they want to remain competitive and keep the Corvette brand going).
Even if the Corvette program was a loss leader for them - it would be a pretty dang good one. They won just about every car award on the planet for the 2014 Stingray. Now here comes the Z06 with more OEM power than pretty much anything not mid-engined and made in Italy or Germany. Given that the new vette chasis has excellent handling attributes -- I'd say they've hit a homerun.
Old 06-06-2014, 10:48 PM
C7 4 Me
C7 4 Me's Avatar
Did you consider any of the other upgrades a Z06 brings, and the price increase to the base C7? Not sure where you're getting 85k, I've heard $78-80k (all speculation at this point), but it's not so outrageous.
Quick Reply: It's Official '15 Z06 at 650HP
