2015 Blind Spot Information System
..... Has anyone heard any speculation about "blind spot" warning systems being intergraded into next years model. I had an opportunity to sit in a convertible top up and a coupe. I'm thinking both would benefit from this technology !!
Agreed, this was one thing that I was truly surprised wasn't on the C7, it seems so simple to implement, especially since it's already on a bunch of cars, can't be too high of a cost, and is of a lot of value, even if it only helps you once.
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
Nope.
The outside mirrors are the only subcontracted fully assembled "outside GM" part on the car. They even arrive to BG already painted (which is why the mirrors don't have orange peel).
I wonder is this has anything to do with it.
While I don't have the convertible, I can speak for the coupe. If you are having issues with blind spots, your mirrors are not adjusted properly. I have absolutely no issues with blind spots on my C7. None whatsoever. You just have to adjust the mirrors out a bit further so as not to be able to see the sides of the car. When adjusted properly, between the rear view mirror and the side mirrors, you have complete visibility of everything alongside you. And rest assured the same will hold true with the vert. As such, I personally think blind spot indicators would be a waste of money. Others may disagree but I suspect that most of those who disagree, don't own a C7 and have not driven one yet and or those that adjust their mirrors like the are used to doing instead of adjusting them properly.
I learned this technique decades ago when I was stationed In Germany. It's now updated and on YouTube. Properly adjusted mirrors are your best friend, yet most American's don't know how to do it.
AutoFocus - How to adjust your car's mirrors - YouTube
One has to wonder if people are getting so lazy that they need an alarm to check blind spots for them on their sports car. Properly adjusted mirrors and looking over your shoulder should occur at every lane change and turn. If people are in the habit of doing it properly there is no need for that kind of nanny. If there not in that habit, then perhaps this is the wrong car for them. I know some will not like that comment but like I said, blind spots are NOT an issue if the mirrors are properly adjusted.
Edit: Great video by the way!
Got tired of the blind spot in my Z and remedied that a few years ago.
Well, first we have 460 horse power corvettes, no one is even close (maybe another Corvette) coming from the rear. Another trick, we have power mirrors, they move at the touch of a button. I change the scan all the time, also the power seat doesn't stay at one position either. Sometimes I have been adjusting to the point that the memory position places everything back to my so called 0 position.
I set my mirrors per the color pic above, it was first put here by me. That being said, I'd take blind spot assist in a heartbeat. The accord has it std. Some of you abhor more tech, I'll take as much as I can get....
I for one love all the tech goodies. I'm an absolute tech junky. I just don't want the car beeping or changing my guage display to tell me somebody is alongside me when I already know it. Sometimes I think certain types of technology make us complacient which is not something we should ever be when driving. Things like mirror adjustments and manually checking blind spots should be second nature or habit. If tech eliminates the need to look over your shoulders or adjust your mirrors, then we loose a good habit. What happens when we drive a rental car and out of "habit", fail to check our blind spots and kill someone? Some would then blame it on the lack of tech. If it was on my car, it would probably be something I would turn off or disable if I could.
I also use this method of mirror adjustment. My C5 is barely able to be adjusted this way though. The mirrors don't travel very far out to the sides but I have them all the way out and it works much better than the way most people adjust their mirrors. My wife could not adjust to this method so when I get in her car which has memory mirrors they adjust for me. I can't understand why people adjust their side mirror to see the same thing as the rear view mirror. Yes it does take a few minutes to adjust but it so much better.
Understood however what happens when exiting the freeway or a road that had two exit lanes side by side and a car is in the lane next to you? I'd guess it will be beeping at you which would drive me bat $hi# crazy. It's been several years since I ever had an issue with a car in my blind spot when I was changing lanes although only a close call. I attribute my current stretch to my lane changing habits and mirror settings. That said, tomorrow I'll probably take out a motorcycle in my blind spot on the freeway. In hindsight, I rode motorcycles for many years and as a motorcycle rider, I'm acutely aware of what's around me when I drive. I'm always scanning my mirrors and keeping an eye out for cars, motorcycles and police. As such, I personally have no need for such a device. That said, as a motorcycle rider, I might however concur that everybody else needs such a device.
PS BMW is not audible at all, you just get a alert light embedded in side mirror and steering wheel vibrates if you want it that way...
"cheers"
http://www.bmw.com/com/en/insights/t...e_warning.html
going on 4 years using 335's with blind spot and a valentine one and never a problem....the system is cam based, with nothing more than a rear backup radar on the side bumper edge...does not play "havoc" with anything...
"cheers"
"cheers"
[IMG][/IMG]
