Stopping coupe roof rattles???
Old 10-07-2015, 08:56 AM
  #121
vetehead
vetehead's Avatar
Originally Posted by Streetrod782
My car was built on 9/15 and I heard the squeak/rattle for the first time this morning after putting the roof back on. Considering my car was just built are these parts different from what was put on in BG? Or are these different parts? Thanks!
This is very close to the cut off date parts inventory at plant. A quick check would be look at finish on receivers if very smooth they are the new ones also pins on roof are white now and also a new smooth material from the black ones.Ken Fitcher posted the tsb a few days ago in another thread there is a picture of the new parts there.
Old 10-07-2015, 09:50 AM
  #122
Streetrod782
Streetrod782's Avatar
Just went out and like and the front two pins are white and the rear pins are black so looks like I have the new ones. Guess they still squeak too.
Old 10-10-2015, 11:46 AM
  #123
Corvetterwb
Corvetterwb's Avatar
This is the thread that has a copy of the TSB. "2014-2015 Removable Roof Panel Noise Bulletin". It has the info on the new parts, etc.
Old 10-10-2015, 12:22 PM
  #124
Corvetterwb
Default C7 roof TSB
Here is the TSB. You can save the graphics to your computer and you can then print them.
Red C8 of Jax (10-11-2015)
Old 10-10-2015, 12:47 PM
  #125
halt00
halt00's Avatar
Any idea how much the parts cost, not taking my car to any dealer until I have to.
Old 10-10-2015, 01:14 PM
  #126
Corvetterwb
Depending on where you order from, the pins retail for about $23 each and the strikers/receivers are over $100 each. A lot of GM parts internet sites discount them.
Old 07-06-2017, 09:27 AM
  #127
VENOM ACR
VENOM ACR's Avatar
Reviving this old thread because I just picked up a 2014 and this noise is beyond annoying. It even has the updated pins (grey up front). How is this even a problem for a $74K sports car that the roof rattle so badly? Like the engineers at Chevy made this amazing car with all this technology and aerodynamics, yet they use a cheap metal on metal creating to hold the roof in place. I can't imagine that they didn't come across this with all the C7 testing. And still haven't come up with a sure fire 100% fix. Ridiculous.
I tried the O-rings, nope. I tried using electric tape, nope. Anyone fix anything that works besides removing the driver side front pin?
Old 07-06-2017, 01:00 PM
  #128
Streetrod782
I just had mine in for the fourth time for a rattle in the door and they adjusted the roof as well. Mechanic said there is a set screw in the rear handle he adjusted to tighten the roof up. It did help quiet the roof down. Of course the squeak in the door is still there...
Old 07-25-2017, 08:02 PM
  #129
Cakasch15stingray
2nd Gear
Cakasch15stingray's Avatar
Default Roof Panel Noise
Mine is so annoying, I'm considering selling it. I've had it serviced twice, latches replaced and it literally sounds like glass cracking every time I turn a corner or hit a bump. I noticed that it is worse in the heat and considering I live in the south, no good. Help!
Old 07-26-2017, 11:05 AM
  #130
wgood
wgood's Avatar
1st check the space between the rear hook and loop and it should be about 1/8 " !!! Mine needed the to be turned twice because it was 3/8 " gap !!! 2nd try to have someone ( while you are driving stick their fingers near the rear posts and see if that helps so the noise ( mine was mostly on the passenger's side ) 3rd take the roof off and put round flat washers over the rear posts ( I used car fender washers from the hardware store ) about 3 each rear side and drive the car to see if that helps !!! I eventually used half washers and stick them between the other washers with the top in place !!! I hope this helps ( it did help in my case except on really bumpy roads !!!! Wayne
Old 08-29-2022, 02:27 PM
  #131
KonaVette
Support Corvetteforum!
KonaVette's Avatar
St. Jude Donor '03-'04-'05
Originally Posted by vettetwo
There is a Service Bulletin for C6 Coupes regarding use of silicone grease for lubrication of the removable tops. I will look for it this evening and post if I can find it. It was very specific about where to apply the silicone grease. I did my 2009 last summer and it is still quiet. GM recommended PTFE sold under the brand name of Super Lube for a few months, but that did not last long. They changed the Service Bulletin to once again recommend silicone grease including the GM part number. It is a small tube, but lasts a long time.
i used Krytox on the entire weatherstripping both side. No more rattle.
Old 08-29-2022, 03:20 PM
  #132
joghotrod
joghotrod's Avatar
Hi Gale,
I was in Kona years ago and met you. Hope you are still doing well.
Jimmy
KonaVette (08-30-2022)
Old 08-29-2022, 08:44 PM
  #133
Rich0071
Rich0071's Avatar
My rattles, I take it off and on a lot. The Super Lube didn't help at all.
Old 08-29-2022, 09:17 PM
  #134
vettetwo
vettetwo's Avatar
I have used the recommendations in TSB 08-08-67-013H which was issued for the C6, but worked very well for my C7.
Note, the version attached is an update in July,2013 with a change in lubrication from GM Super Lube to Dielectric Silicone Grease. The recommendation to use Super Lube was short lived because it did not work very well as you have experienced. I highlighted the note on page #1 where they make the recommendation.
File Type: pdf
Old 08-30-2022, 09:56 PM
  #135
KonaVette
KonaVette's Avatar
Aloha Jimmy,
How you doing man. Any chance you coning back to Paradise?
Old 08-31-2022, 10:40 AM
  #136
Chevy Cust Svc
Chevy Cust Svc's Avatar
This is certainly not what we like to hear, Rich0071. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: Rich0071/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Quick Reply: Stopping coupe roof rattles???
