Elite Engineering's Catch Can and Clean-Side Oil Separator
We will update our website purchasing to make this easier, but this is what you need:
1) Base C7
- Standard Catch Can with Single Exit Port, No Check Valve
- Clean-Side Separator is always a good option
2) Z51 with Dry Sump
-2nd Gen E2 Catch Can with two Exit Ports
- two check valves, one on each Catch Can Exit fitting
3) Z51 with Wet Sump
1) Base C7
Wonder why GM thought there should be a check valve between the valley area and the intake manifold?
No problem, really sorry for the headache, but we'll make it right and guide you through the return/exchange program.
The C7 being direct injection is very subject to the intake valve coking issues (google search: " Direct Injection Intake valve coking" and click on images) as all DI engines have this issue.
GM has greatly improved the oil separating function of the valve cover and valley cover for 2014, but it is still an issue so ALL oil and related blow-by compounds must be trapped before they can enter the intake air charge....far more critical than ever in the past with any GM V8 before....so this is new to some that may not have been intimate w/DI engines (GM 3.6 v6 DI since 2008).
The Dry-Sump (Z51 option) is especially prone to this, not as much an issue with the Wet-Sump.
The importance of the dual outlets on the Catch Can is that many vette owners will run at WOT from time to time, and during that time there is zero measurable vacuum present in the intake manifold to maintain the correct direction of PCV flow, so adding that extra barb allows the flow to maintain proper direction because at WOT there is a good amount of suction just upstream of the Throttle Body where the reversion pulses do not reach (until over say 8,000 RPM which they won't reach).
You only need the check valve on the intake manifold side in this case.
Elite Engineering needs to edit this post and correct the misinformation. There are NO Z51 with a WET SLUMP. Show some pictures of the correct install. Please correct your information Elite Engineering is causing a lot of grief and trouble.
It is my opinion, at least with my Z51, ProCharger setup that there is NO OIL entering the intake from what Elite deems the "dirty side". We placed a Q-tip in the hose and there was no oil, dirt, etc. It came out clean. The oil supply canister was the culprit and we had a bunch of oil coming out of the SC BOV until Corvette Connections installed a catch can between the supply canister and the intake.
We no longer have oil entering the intake, but that catch can fills quickly. Seems odd that this is not corrected by GM.
I am still curious as to how much oil was entering the intake BEFORE supercharging. If stock C7 cars have this problem, then I think it is GM's problem...
-Jim
-Jim
I'd like to hear from C7 owners who have installed this Elite Catch Can. Did you have the Z51 or not and which Can did you use?
I strongly believe in a catch can and have always run them and they are extremely important on DI Engines so I'm about to pull the trigger on this but the images shown in this thread by Elite of the C7 Engine bay do not look like mine as far as the hose routing for the Air Separator.
Did you guys have to buy any Vacuum hose to add the can? If so What size diameter hose and what length?
I have a Base model C7.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I have a base so installed the elite "good" can, all you need , as base cars don't "burp"
#33
So, let me see if I understand this correctly, since I am in the process of installing my Elite Best unit. The outlet hoses from the catch (the sides) are being routed into the intake system, right? The 'Vaccum Barb "B"' is where exactly...post throttle body? Or is it pre-throttle body? From the pictures it looks post, but I would think that would be a source of leaked air into the intake.
The extra connection "C" for the Best unit is connected to the intake elbow, pre-throttle body. So if both of these are essentially connected pre-throttle, what's the difference between this and just venting it to atmosphere? In theory, if the catch can is doing its job, there is no oil coming out. Is it just a technicality to be emissions legal ("closed" loop)? Does it have something to do with the pressure drop in the intake?
#40
E-Ray, 3LZ, ZER, LIFT
Received 9,646 Likes
On the bottom of page 6, you'll see the one line without the check valve goes to where the existing PCV line went, that is after the throttle body. The line you're replacing does not have (or need) a check valve. I elected not to install the line with the check valve, which goes to a hole drilled before the throttle body. If you use both lines you need one check valve, so it doesn't just move air from one side to the other thru the can.
If I was tracking the car (lots of prolonged full throttle operation) or had a supercharger, I'd add the other line. Instead I just have a plug threaded into that 2nd outlet hole.
You're call on dealing with who you want.
