Install Catch Can in C7 Info?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
There is only one PCV valve and one intake for it into the throttle body/MAFS...
Just an educated guess on my part.....
Moderator
Clean Side Oil Separator
Elite Engineering, the leader in catch-can solutions announces the latest addition to their proven line of oil separating catch-cans with the "Elite Clean Side solution". The Clean-side solution addresses that small amount of oil vapor that enters the intake air charge up-stream of the throttle body during WOT operation when the intake manifold vacuum is not present. The Cleanside solution allows 100% MAF metered air entry while trapping the oil during wide open throttle operation and allowing it to return back into the valve cover as soon as the throttle is lifted. Available in Chrome, or any other popular color to match your exterior and 1/2 the price of the plastic GM unit. This is a direct replacement for your stock Oil Fill Cap.
Models for both the V8 AND V6 Camaro engines.
Added to the Elite original, or New E2 catch can, this is your COMPLETE PCV oil ingestion solution.
Retail $99.00 plus our typical $5.00 shipping
#35
#36
Are you guys saying f***ing GM didn't fix the oil intake issue with their PCV on their FOURTH engine iteration? Geez, unbelievable. It's probably the only damn car in the market with this problem. Forgot to ask this question on my thread, but now I know. Not a huge deal in itself, but that tells me GM's quality control hasn't improved much. Will check out the C7 today, but am not going to skimp on quality just because it costs less this time.
