Michelin Pilot Super Sport (how many miles)?
Old 04-21-2014, 09:41 PM
Stingray Al
Stingray Al's Avatar
Default Michelin Pilot Super Sport (how many miles)?
Well, I have 4000 miles on my Pilot Super Sport tires on the Z51.
Just measured the tread on the rears and they are at 7/32
Is that about right?
Does the wear seem excessive ?
Is the average?
I don't track the car or smoke the tires. However, i do like to punch the gas off the line.
How many miles can I expect from these tires?
Al
Old 04-21-2014, 10:04 PM
shaan
shaan's Avatar
Is the average?
Al
I think you should get around 12-15k on them
zare191
zare191's Avatar
I think they have 9/32 new, so based on your mileage, it looks like anything over 16,000 would be a stretch.
Old 04-21-2014, 10:06 PM
wgood
wgood's Avatar
Is the average?
Al
A Discount Tire guy told me 30k on these tires when I was in the store to having another car's tires rotated !!! Wayne
Old 04-21-2014, 10:36 PM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
Few people actually get that IMO. Besides, the 30K warranty is cut in half for staggered set ups... which, of course, the C7 has
Old 04-22-2014, 09:23 AM
Stingray Al
Old 04-22-2014, 10:26 AM
wgood
wgood's Avatar
Well when I bought my C 5 coupe with 40 k the rears had been replaced and had 80 % left and the fronts ( the originals needed to be replaced ) So the real old question is how the car was driven and how many highway miles vrs street use !!! Wayne
Old 04-22-2014, 11:08 AM
gthal
gthal's Avatar
Agreed that driving style plays a huge role. However, the more aggressive the tire (i.e. sticky) the faster it will wear out. The tires on the C5 would be no where near as sticky and soft as the PSS.
Old 04-22-2014, 12:50 PM
BigJoe
Support Corvetteforum!
BigJoe's Avatar
But I think the road surfaces make a difference too. Smooth asphalt vs rough or ridged concrete for example. Around North TX most roads are concrete and I could get no more than 10-12K miles on my C6 GS tires. My C7 non-Z51, however show almost no wear in 2K miles.
Old 04-22-2014, 12:58 PM
kp
kp's Avatar
Yep. lots of concrete here as well, '12 GS tires were done at 9K even with the 'street' alignment. I dont drive that aggressively, but the one good thing is the rough concrete hooks hard
I would be thrilled to get 15K from the base C7 tires, not sure hpw much quicker the Z51 tires will wear..
Old 04-22-2014, 02:32 PM
rsl2715
rsl2715's Avatar
I'am shooting for 30,000.with no hard breaking and no burn-outs.I did this on my C-5 got 45,000 on run flats Pilot Sports.R
Old 04-22-2014, 02:40 PM
Stingray Al
m
I'm not driving my car hard. But I'm down 2/32 after 4000 miles. I'm hoping for 15k of use off the rear tires.
Just not sure if I'm going to buy the oem tires
Old 04-22-2014, 02:53 PM
Nate GM
Nate GM's Avatar
About how much does it cost to replace all four of these tires on a Z51? I did a quick search online and it looked like $800-$900 but that seemed a little low.
Old 04-22-2014, 03:22 PM
mjw930
mjw930's Avatar
About $1600 / set.
Here in FL the roads are tough on high performance tires. It's all the crushed shells in the mix on the older roads.
If I can get 15K out of the set I'll be thrilled but that will be more than 3 years use so I'll probably replace them before they are worn out (or trade the car on a Z06 )
Note, that as they wear past the 4/32nd mark the ride quality will fall off dramatically. It's not uncommon to replace extreme/max performance tires before they get to the wear bars simply to recover performance and ride quality.
It's also worth noting there are a number of tires now coming in the Z51 sizes at close to half this price though only the Michelin's are run flats http://www.tirerack.com/tires/TireSe...=60100&tab=All
Old 04-22-2014, 03:23 PM
BADA BING
BADA BING's Avatar
They are around 400 a tire give or take depending on vendor
I got 20k out of my c6 GY
Old 04-22-2014, 07:01 PM
smajicek
smajicek's Avatar
I see members posting thread debt on the rear tire but have you looked at the inside edge of the front tires?
Old 04-23-2014, 12:07 PM
rsl2715
rsl2715's Avatar
Is the average?
Al
I also have a Z-51 1800 miles all four tires read 8/32. went to the dealer to measure a new non-Z51 it was 10/32.My question what was the starting point on a Z-51 same 10/32?????Help.R
To Michelin Pilot Super Sport (how many miles)?
Old 04-23-2014, 12:36 PM
zare191
zare191's Avatar
Go to tirerack.com. They have every fact you would ever want to know about every tire they sell.
Old 04-23-2014, 12:54 PM
rsl2715
rsl2715's Avatar
Thanks, did and they do have total facts."FYI" tread Z-51 new Front 9/32" rear Z-51 9.5/32".R
Old 04-23-2014, 12:59 PM
TEXHAWK0
TEXHAWK0's Avatar
Is the average?
Al
With 4,000 already on the tires, take a look at the inside edge of the front tires to see if the alignment needs to be checked.
The alignment can be within "factory specs" and still be too aggressive for normal street driving and reduced tire wear.
On my last Z06, I could see inside wear after only 1,000 miles.
Quick Reply: Michelin Pilot Super Sport (how many miles)?
