** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
Old 03-26-2014, 09:15 PM
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Default ** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
C7 Corvette Front License Plate Brackets
If you live in a state that requires a front license plate, we have two great solutions for your C7 Corvette. Both of the Top Flight Reproductions front license plate brackets allow more air flow than the standard GM grill mount and attach with just two fasteners. There is no drilling or modifications required to your corvette.
** Features of the "Low Profile Mount" include less blockage of air flow, a sturdy aluminum construction with a black powder coat finish that attaches using existing screws. **
** Features of the "Grill Mount" include a Slim-Line look, an increase in air flow through the grill compared to the GM mount as well as ease of installation. **
NOTE: The GM C7 and C6 Body Colored License Plate Frames (sold separately) can be used with all of the Top Flight Front License Plate Brackets to enhance the look of the front plate.
ORDER HERE: http://www.topflightrepro.com/corvet...brackets.shtml
C7 Front License Plate Bracket "Low Profile Mount"
Shown with optional GM colored frame
Mounts to the bottom of the lower front bumper using two existing screws
C7 Front license plate bracket "Grill Mount"
Return the GM Front License plate bracket P/N 22830069
back to us and we will issue you core refund
(the P/N is located on the back side of the part).
Mounts using the Fastener Kit shown below
Grill Mount Fasteners qty of 2 per kit
** Please note that these are not supplied with the above
"Grill Mount" Front license Plate Bracket. If you have the GM
Grill mount you can use the same two fasteners. If you do not
have the GM Grill mount you will need to order this fastener kit. **
Wolfie (06-16-2016)
Old 04-02-2014, 10:38 AM
Old 04-02-2014, 05:36 PM
Patriot77
Support Corvetteforum!
Patriot77's Avatar
Do you have any suggestions for the rear standpoint as to not scratch the paint??? Many of these frames hug up tight to the car. I was wondering if anyone makes a felt type or even a rubber washer that could go against the car before mounting the rear plate. Just trying to protect the paint from getting a mark on it. Hope to hear from you. Thank You.
GregNYC (11-13-2017)
Old 04-02-2014, 09:08 PM
coupeguyz51
coupeguyz51's Avatar
Very slick! I like it a lot!
Old 04-03-2014, 07:09 AM
I have had these colored frames on both of my C6's (10 years) and have never had a scratch or mark
Old 04-03-2014, 07:10 AM
Thank you
Old 04-03-2014, 08:29 AM
LIStingray
LIStingray's Avatar
I put the 1/8" thick felt (from Home Depot - light brown in color) cut into 1" wise x 4" long strips on the license plate (not on the car) just above the bottom of the raised section of the rear fascia. It keep the plate and frame off the car's paint.
chuckrbt (07-27-2018)
Old 04-06-2014, 06:27 AM
Old 04-06-2014, 06:37 AM
Nyvetteguy007
Nyvetteguy007's Avatar
Need to order this...a BIG improvement over the stock frame
Old 04-09-2014, 06:53 AM
Old 07-10-2014, 08:34 AM
AFVETTE
AFVETTE's Avatar
I've used this method for over a decade. It works.
Old 07-10-2014, 08:57 AM
TKay
TKay's Avatar
I really like the looks of the grille mount one. That is the one I will get when my car comes in.
Old 07-10-2014, 07:22 PM
thank you TKay
Old 07-21-2014, 10:50 AM
TKay
TKay's Avatar
Just curious, has anybody experienced overheating problems with the grille mounted bracket?
Old 07-25-2014, 11:08 AM
None so far and doubt anyone would with our grill mounted bracket, this allows more airflow than the GM Aero mount and we also have the Low Profile mount witch opens up considerably more area.
Old 08-19-2014, 04:08 PM
Yukonboy03
Yukonboy03's Avatar
tag for home viewing
Old 08-21-2014, 07:42 PM
50MileSmile
50MileSmile's Avatar
In case you're wondering about the quality of products from Top Flight Reproductions: Yesterday, I sold my '07 C6 with the TFR front license plate holder that has been on the car for almost all of its 8 years. The detachable holder looked brand-new - no nicks, no scratches, no runs, no drips and no errors. The bracket bonded to the bumper hasn't moved a millimeter and looks brand-new. The screws and other hardware all look brand-new.
So, credit where credit is due: These folks turn out quality products that last. I have no interest in this company other than as a satisfied customer, and I can't wait to do business with them again.
To ** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
Old 08-26-2014, 11:12 AM
Thank you for the kind words 50MileSmile
Old 08-31-2014, 06:15 AM
Old 08-31-2014, 08:53 AM
hdwideglide
hdwideglide's Avatar
Same here. I've had mine on my '07 every since I've owned mine and getting ready to order another for my '15. Peter is great people and have fantastic products.
Quick Reply: ** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
