Discard my new tires?
#41
i know that many buyers have exposed their tires to far worse conditions, with no problems, but there appears to be adequate evidence that there is at least a potential problem here. i for one replaced my summer oem tires at delivery with all season michelins (hmm....) so as to obviate any problem. this is to me a hugely serious issue for gm to address--along with the other many problems, e.g., faulty ignition switches, et al., and a more serious one for their clients. it transcends an issue of who is responsible to pay for what replacements.
i had only one problem with cracks in tires. i owned a boat, with a trailer, which i bought used. i did not go over the tires very carefully, and at first glance they looked fine. little did i know that they had been stored outdoors for a number of years in weather that varied significantly between winter and summer. on the way home from a vacation, i had a blow out, and very fortunately for me lived to tell about it. there was no on-coming traffic when it blew, but did that trailer ever whip back and forth. be careful guys. we all know that corporations in a capitalist economy, subject to huge profit pressures, are reluctant to jump into these types of things, and take proactive action.
#42
note also that gm advises all dealers to deliver a copy of the notification to purchasers. i guess my dealer forgot. i presume you all got your copy.
#43
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
#44
Hey Everyone,
Just a friendly reminder! Per the 2014 Chevrolet Corvette Owner’s Manual; we recommend installing winter tires on your vehicle if driving temperatures are frequently below approximately 5 degrees Celsius/ 40 degrees Fahrenheit. Winter tires are also recommended on snow or ice covered roads. If anyone has any further questions, feel free to private message us! Hope this helps.
Jennie R.
Chevrolet Customer Care
Jennie R.
#45
2015 C7 of the Year
Hey Everyone,
Jennie R.
Jennie R.
#46
Hi Jennie! Thank you for your post. I have a follow up question that I imagine others would wonder about as well. If the bulletin that went out to the dealerships says that damage may occur when driving on these tires when the temperature is below 20F, and further advises not to drive on them at all in that situation, is that what Chevrolet Customer Care is instructed to tell us as well? If not, why the discrepancy between the bulletin and what you posted for us? In other words, what is the bottom line from Chevrolet on this issue, particularly when dealing with sub 20F temperatures? Thank you!
Our team at Chevrolet Customer Care has the same advice as the bulletin and your owner’s manual. Both the bulletin and owner’s manual advise that our enthusiasts do not drive their corvettes without winter tires in temperatures below 40 degrees Fahrenheit. We recommend this because high performance tires become susceptible to cracking and reduced traction at this temperature. Consequently, 20 degrees Fahrenheit is when we state not to use high performance tires at all. I hope this helps and if you have any further questions, you know where to find me!
Jennie R.
#47
GM has earned a reputation for holding back critical safety info.
#48
Hey Jagamajajaran,
Jennie R.
Jennie R.
#49
Then maybe GM should suspend Corvette sales in the northern states during the late fall, winter, and early spring months. (about 5 months total). My dealer thinks the tires cracked WHEN IT CAME OFF THE DELIVERY TRUCK when it was about 18 degrees out. In those conditions during a slow speed turn, the tires go CHUNK CHUNK CHUNK, that's when the tires probably cracked with 4 miles on the odometer. All I did was drive it home 12 miles at about 38 degrees. Your statement is just unacceptable.
Not to mention that GM and the dealers are doing a poor job of communicating this issue. If I didnt read it here I'd have no idea and could be driving my car.
#50
2015 C7 of the Year
Hey Everyone,
Jennie R.
Jennie R.
Hey Jagamajajaran,
Jennie R.
Jennie R.
Thank you for the reply. Here's where GM needs to improve their communication with owners, as has been stated by several in this thread:
The owner's manual tells us the same thing you initially posted: "we recommend installing winter tires on your vehicle if driving temperatures are frequently below approximately 5 degrees Celsius/ 40 degrees Fahrenheit."
However, it appears that GM has determined that there are other considerations that should be taken due to the tires cracking when the temperature is below 20F. So the safe statement that GM appears to want to make now is the statement you made in your reply: "Both the bulletin and owner’s manual advise that our enthusiasts do not drive their corvettes without winter tires in temperatures below 40 degrees Fahrenheit." However, the owner's manual does not say that. Instead, it recommends a change of tires if frequently driving in temperatures below 40F.
This is not intended to put you on the spot at all. I appreciate what you do for us and the fact that you monitor the site and provide assistance when you see someone needs assistance. This is, instead, intended to put GM on the spot for two things: 1) Communicating better with their customers regarding the issues with our tires and recommendations for preventing damage due to sub-40F temperatures. 2) Providing support and assistance for those with issues who were unaware that this could be a problem when the manual provides for driving in temperatures below 40F as long as it is infrequent (with no mention of the issue that develops when the temperatures are below 20F).
Thank you for being our advocate!
#51
8th Gear
I am on my second season of Michelin PS 2 run flats. I have yet see to see a crack in any of them, but I am sure going to look a little closer, now that a problem has been pointed out.
My car is store inside with a "flat stopper" under each tire, but our cold ND winters still reach -10 or lower, even in the garage!
#52
#53
The owner’s manual information regarding tires and the TSB information are not the same. There is a simple reason for that; when the car and tires were developed GM and Michelin had no idea the tires would crack under certain conditions.
This is verified by the service manual, it doesn’t say a thing about cracks but warns about using summer tires in the snow. Not because they will crack but because you will slip, this is common sense.
A TSB is issued only because a problem was found that IS NOT NORMAL. It happens after the fact and it’s not covered in the owner’s manual. Why issue a TSB for a problem that’s normal???
GM has done the math, they are willing to gamble on the tire issue and not recall. They will deal with customers on a case by case basis. Overall they are being very successful convincing most owners the cracking is normal. Its not. TSB says replace tires. Some cases may be mild but I've seen some I wouldn't drive on.
Why would anyone on this board think this is normal??? Certainly not helping the cause. Z51=Track Day=180MPH, you don't want to add cracked tires to that equation!
#54
To start with, I took a picture of the small cracks and will show it to
an authorized Michelin dealership and get his opinion. GM's TSB
seems to say discard and replace if ANY cracks are found.
#55
Is there a consensus on the cracked tire issue? I pulled my front rims off my Z51 after 50mi. (I took delivery yesterday), and found both fronts with cracks in them. Took one to the service manager at the dealer.He pulled a TSB stating that they should be discarded. Manager said I probably shouldn't have driven the car home yesterday. Huh? The temp was about 35. He said he might get one replaced but not both. My question is are these safe to drive on and should the dealer be obligated to replace these?
#56
Hey Jagamajajaran,
Jennie R.
Jennie R.
Jennie, you need to put this information out to your company since they are driving the cars in temps below 20 for transportation reasons. In addition you should restrict all sales to South Florida only.
There are lots of very high performance tires. Most don't give great traction below 40 degrees however they can be driven on without damage. GM needs to step up and get these tires recalled and new tires installed without a major engineering error and design flaw installed.
#57
I may be in a similar situation in a few days, I am picking up a new C-7 in NH and am worried about cracked tires.
SEE THIS THREAD
I am assuming that if the dealer delivers the car he is responsible.
I am going to make sure the car is stored inside the night before I pick it up. If I start out with warm tires and keep driving the tires should stay warm from friction as long as I do not stop too long. If I make it far enough south I should be in an area where the weather should be warm enough for there not to be a problem.
I would like to see pictures of your tires, to see how bad the cracks are. From what I read small cracks are not bad. If the service department says they need to be replaced they must be pretty bad.
SEE THIS THREAD
#58
The Goodyear F1 supercar tires that came on my Camaro 1LE are just as bad, but at least there was a thing hanging from the shift **** telling you that you should not drive below 40 and not move the car under 20 degrees. If the tires are exposed to below 20 degrees you are supposed to let them warm up gradually over a 24 hour period.
Any summer performance tire is going to have issues at very cold temps, because their compounds are soft, thats what makes them sticky.
#59
8th Gear
#60
I would be livid if I picked up my new car in 30 degree weather, my dealer let me drive off the lot, the tires cracked, and then I did not get new tires mounted for free at the dealer of best tire shop in town if the dealer's shop stinks. Many non-car nuts buy Corvettes, and how is a brand-new owner going to know about the tires?
Tesla just announced they are going to retrofit all Model S cars with a new skid plate to protect the battery pack from underside impacts--no charge. Now I do not think Tesla qualifies for sainthood, but this is related I am sure to the fire issue and they are not stonewalling here or trying to blame the consumer.
Chevy should replace these tires. Pronto. If they are going to let people drive their new Z51s from the dealerships in 30 degree weather, then dealers should mount winter tires before you drive out and remount your summer tires for free when the weather warms up. After that, your nickel, but that is just how it should be....
If dealers don't play ball with Chevy on this, then Chevy should cut their Corvette allocation....
