SD help
SD help
I'm going nuts! I downloaded my cd's to the computer. Transfered them to a sandisc cruzer and plugged it into a usb port. the manual says to get a sd to show up somewhere. I've pressed every button and icon and says -no device found. On the home page there are arrows on the extreme right and left. The manual says to push them to get more screens but nothing happens. I've been using the steering wheel controlls when set on audio but still no sd. HELP!!!
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
So if you press the MEDIA button (black "real" button), it doesn't show your USB stick (SD card and USB stick are two totally different things)?
What format did you save your CDs "to your computer" and what format are they on your SD card/USB drive?
sd
I dont know. I have awindows vista op system. Is that the format.
I believe Ken Horse said that the C7 doesn't like the SanDisk, I have one but it's a micro that has a USB adapter and it works fine. Try giving that a try.
