Infotainment HMI issues
Old 07-24-2016, 05:12 PM
rmvoort
Cruising
rmvoort's Avatar
Default Infotainment HMI issues
Having trouble with my infotainment system. Screen shows only @asking for media update " times out after 20 minutes and then go blank and starts again. Dealer claims they have never seen this issue. See attached picture.
Old 07-24-2016, 07:24 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
Looks like its waiting for the update media.
Old 07-25-2016, 02:33 AM
SgtC6
SgtC6's Avatar
It needs a new HMI module. Hopefully yours doesn't take as long as mine. Took four weeks to get the new HMI and have it programed correctly. I ended up getting into contact with right guy who had it fixed up in short order.
Old 07-25-2016, 07:52 AM
rmvoort
Cruising
rmvoort's Avatar
Thanks for your input. I'm glad you got the issue resolved.
Old 07-25-2016, 09:30 AM
SgtC6
SgtC6's Avatar
It was a huge pain since the issue hadn't been seen before. If you have issues getting it fixed, I can forward you my case # which should speed things up.
Hoping for a speedy fix for you. 😀
Old 07-25-2016, 10:29 AM
rmvoort
Cruising
rmvoort's Avatar
That would be great. Thanks
Old 07-25-2016, 10:30 AM
rmvoort
Cruising
rmvoort's Avatar
Thank would be great if you could send me your case number and any info you think that would help.
Old 07-25-2016, 11:16 AM
SgtC6
SgtC6's Avatar
Sent you a PM.
Old 07-25-2016, 11:24 AM
red 1
red 1's Avatar
Mine's been in the shop for a week waiting on the new screen it went totally blank, I hope it doesn't take long as yours did I'll have them put it back together and call me when it comes in.
Old 07-25-2016, 12:30 PM
rmvoort
Cruising
rmvoort's Avatar
That's what I did also until the part comes in.
Old 01-17-2017, 12:43 PM
rvomacka
2nd Gear
rvomacka's Avatar
Default Me too
Please forward the case number. My month old Corvette did the same thing today. Sad.
Old 01-17-2017, 07:34 PM
SgtC6
SgtC6's Avatar
Here you go. Hope it helps. Biggest problem was part being on backorder. If yours is not on backorder then 3/4 of the battle is over.
Case # 8-2131412341
Old 01-28-2017, 07:58 AM
N2TU
Support Corvetteforum!
N2TU's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
I now have the same problem! What was your final fix?
Thanks!...
Old 01-28-2017, 08:03 AM
Larry/car
Larry/car's Avatar
Post your C7 model years that are having this problem. It will be interesting to see if there is a bad batch of HMI components affecting certain year cars.
Old 01-28-2017, 08:18 AM
N2TU
N2TU's Avatar
2017 GS. Produce the first day of 2017 GS model production.
Thanks.
Old 01-28-2017, 10:16 AM
defaria
defaria's Avatar
Received 1,203 Likes on 732 Posts
Love that it's running Linux though...
Old 01-28-2017, 02:33 PM
N2TU
N2TU's Avatar
I posted this on another HMI thread....so you may get duplicate. Sorry but I wanted to make sure everyone has the info....
Called the Infotainment center HOT LINE. (855) 478-7767
There is a GM bulletin relating to this problem...it is 16-NA-341. The HotLine person was extremely helpful and was very familiar with the problem. She will call my local dealer's service advisor (the guy I saw yesterday) and inform him of the Bulletin. I have an appointment Monday to see him and a case number will be opened.
So if anyone experiences this, cut through the red tape. The local dealer service center probably will not be aware of the Bulletin.
Call the Infotainment HotLine. They will get the ball rolling.
I hope this helps!
Regards all.
To Infotainment HMI issues
Old 01-30-2017, 03:16 PM
N2TU
N2TU's Avatar
The saga continues! Took the GS into service today. They had it for 3 hours before they finally gave in an ordered a new HMI unit. The Service Rep seemed a little ticked that GM called them and gave them the bulletin number...but so be it!
An appointment is scheduled for this Wednesday to have the HMI swapped out. We will see if they can get a new one by then.
More when it is swapped.
Old 01-30-2017, 03:17 PM
N2TU
N2TU's Avatar
By the way if it weren't for this Forum and its members, I would not have had any of the information to proceed.
This Forum's collective knowledge is amazing! Thanks all!
Old 01-30-2017, 07:56 PM
tome
tome's Avatar
My new GS (2400 miles) did this last week. I disconnected the battery for 5 minutes and it has been fine since then. Anyone have it happen multiple times?
Quick Reply: Infotainment HMI issues
