Extreme Oil Leak!!
Old 03-10-2014, 11:21 AM
C7pimp
C7pimp's Avatar
Default Extreme Oil Leak!!
My baby (with only 11 miles on it) literally puked almost all of the oil out.
It puddled everywhere underneath the hood, sprayed the hood liner on the driver side, coated the entire undercarriage, and even coated the entire back of the car in oil. I was getting on the freeway, and at 70 mph, a massive cloud of white smoke shot out the back of the car. It didn't make a noise like a pop, crack, or anything that I could hear.
The car still will run perfectly. (I rolled it off the freeway with the engine off) and turned it on and drove it home about 1.5 miles away. Engine did not blow, ran very smooth.
The huge cloud of smoke, I assume, came from oil being sprayed all over the exhaust manifolds.
I checked the oil level and it is basically bone dry.
I had it put on a tow truck to the local dealership.
Never heard of such a catastrophic oil leak. It literally emptied all of it.
Every hear of something like this?
Old 03-10-2014, 11:24 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes on 2,065 Posts
2015 C7 of the Year Finalist
That sounds truly disastrous! I've never heard of such a discharge of oil from the engine.
Elmer
Old 03-10-2014, 11:25 AM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
Sounds like maybe the oil filter gasket failed? I had that happen to me many many years ago on a Honda
Wouldn't be unusual if it was overtightened....
Old 03-10-2014, 11:26 AM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Is your car a Z51?
Old 03-10-2014, 11:31 AM
FLYNLO
FLYNLO's Avatar
...and just because it didn't register on the dipstick does not mean it was "bone dry". And be careful about how you express yourself reference "driving 1.5 miles" after saying it was bone dry. There could be warranty implications for continuing to drive it after you already knew something was very wrong.
Old 03-10-2014, 11:35 AM
mjw930
mjw930's Avatar
What did the oil pressure gauge show and did any service engine or oil warning lights come on?
From a previous post I'm assuming this is not a Z51.
Old 03-10-2014, 11:49 AM
Woodson
Woodson's Avatar
Received 1,364 Likes on 789 Posts
Uhhh. Just sayin'
Old 03-10-2014, 11:52 AM
Crossed Flags Fan
Crossed Flags Fan's Avatar
Yikes!!!!!!!!!!!
Old 03-10-2014, 11:54 AM
SRQStingray
SRQStingray's Avatar
Originally Posted by Woodson
Uhhh. Just sayin'
Why in the hell would you drive it home? To make sure it was completely destroyed?
Old 03-10-2014, 11:56 AM
FLYNLO
FLYNLO's Avatar
Uhhh. Just sayin'
Which was my point ref the warranty implications.
C7pimp
C7pimp's Avatar
Correct, it is a Non-Z51.
The check engine light did NOT come on.
Old 03-10-2014, 12:05 PM
C7pimp
C7pimp's Avatar
I was so close to home, all I could think of was to just limp it home and check it out. When it drove just fine, I guess I was a bit confused, in that weird mental state, and just drove it home.
Stupid, thinking back on it. Sometimes you just get into a mind set and go with it.
No flames, no smell, no CEL, temp gauge read normal, car drove fine, I zoned in to getting it home. Had oil not smoked off the exhaust manifolds, I wouldn't have had a clue anything was wrong.
Old 03-10-2014, 12:08 PM
C7pimp
C7pimp's Avatar
And my driveway has the most horrible oil stain I've ever seen. It dripped off from all over the underside of the car, not just the engine bay area.
Gonna have to clean that up!
Old 03-10-2014, 12:11 PM
ATX-C7
ATX-C7's Avatar
Plug still on? Filter in place? Any pics?
Old 03-10-2014, 12:24 PM
mjw930
mjw930's Avatar
You didn't mention it but did your OIL GAUGE show pressure at all times?
It's possible this is a simple leak from the oil line leading into or out of the oil cooler, assuming there is an external cooler on the LT1. The loss of 2 quarts, enough to be below the dip stick, would look like the Exxon Valdez oil spill yet still provide enough oil to maintain pressure and hence save the engine from damage. It could be something as simple as an oil line not being tightened and it backed off a little. Certainly unacceptable but not catastrophic unless it happened at speed on the highway and you didn't notice it till your oil light came on.
Old 03-10-2014, 12:48 PM
C7pimp
C7pimp's Avatar
No pics. Filter was there.
Hard to see under such a low car.
Old 03-10-2014, 12:49 PM
KenHorse
KenHorse's Avatar
My money is still on the filter gasket.....
To Extreme Oil Leak!!
jsiddall
jsiddall's Avatar
If the leak was on the way back to the pan and it never went dry then the oil pressure never dropped an no harm was done to the internals.
Old 03-10-2014, 12:50 PM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
If memory serves me, the engine is programmed to shut down on really low oil pressure so I am thinking there was still enough oil in the sump to get you home without oil pressure getting too low.
Old 03-10-2014, 12:56 PM
C7pimp
C7pimp's Avatar
The oil light never came on, and the gauge, honestly, I didn't check while the car was still on because I just drove it home real quick, parked it, and pushed it when I had to move it. (Electronic parking brake is annoying as hell btw, lol)
Quick Reply: Extreme Oil Leak!!
