Running cold weather friendly rubber, what a difference!
Old 03-01-2014, 06:13 PM
Periokid
Support Corvetteforum!
Periokid's Avatar
St. Jude Donor '06
Default Running cold weather friendly rubber, what a difference!
I know it is an ongoing debate but I knew I had to get winter rubber for my Z51.
I decided the best way would be to get a set of standard C7 rims and put Michelin Pilot A/S 3 tires. The car is not driven in the snow. I have my daily for that.
I finally got it all together. I bought a used set with TPMS included. Tires from Tirerack.
While the look is "OK" the performance on cold streets is incredible.
I could drive the car with the Z51 Pilots but any aggressive inputs, especially throttle, would spin the tires with ease.
Now I have so much more grip. Heavy throttle now just causes rapid acceleration, not tire spin and oversteer (in turns).
I did have a small issue with the outside wheel weights and front caliper clearance but that was fixed by placing the weights the long way to avoid the calipers.
Also the ride is smoother. Just something I noticed but was not complaining about.
Come warm weather, I'll go back to the Z51 wheels and tires.
Old 03-01-2014, 06:18 PM
themonk
themonk's Avatar
Location: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
Received 1,456 Likes on 799 Posts
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
did you also notice that there's no more hopping and skipping during slow tight turns?
Old 03-01-2014, 06:20 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
You know, you are right! No skipping. I forgot about that!! LOL!
Old 03-01-2014, 06:27 PM
PARANORMAL
SUPPORT AUTISM
PARANORMAL's Avatar
St. Jude Donor '10, '14
Took mine out today and just put it away in time for more snow tomorrow.
Old 03-01-2014, 06:58 PM
LIStingray
LIStingray's Avatar
Is that a Z51 that you put Base wheels on?
I thought (based upon comments here, that the Base wheels don't fit the Z51 fronts.
Old 03-01-2014, 07:11 PM
Greg00Coupe
Greg00Coupe's Avatar
Received 1,974 Likes on 1,140 Posts
Yea tell us more about this....... You went from 19 20 inch Z51 wheel and tires to 18 19 inch set up without any clearance issues? Other then the inside wheel weights you mentioned???
I think gm Wheels will hold up to the elements better.
Old 03-01-2014, 08:20 PM
Kyflyer
Kyflyer's Avatar
Thanks for the information, I have already ordered a set of the Michelins and I am having them installed next week if this eternal winter will give me a break. Are you carrying a plug kit and a compressor? I have done that in the mini for some time and will transfer them from one to other. I had already made up my mind to make the switch as it transformed the handling and ride comfort in the mini exponentially!
Old 03-01-2014, 09:13 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
Where is Suffolk are you? We could be neighbors.
Old 03-01-2014, 09:18 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
My issue was the wheel weights only. They just barely rubbed when the wheel rotated. They hit the brake pads where they stick out of the calipers.
The weights that were on the car from my tire guy were long and narrow. They were placed with the long way going from outside the wheel to the inside. All I needed to do was mark their location on each front wheel, take the weights off and separate all the weights (4 on one side and 3 not the other wheel). I then cleaned off all of the double sided tape, and replaced them so they where short from outside to inside (i.e. rotated them 90 degrees).
Works ok so far!
Old 03-01-2014, 09:20 PM
Woodson
Woodson's Avatar
Received 1,357 Likes on 785 Posts
Old 03-01-2014, 09:21 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
Right now I am not traveling far from home. The weather has really limited the use of the car. I have my AAA card with me in case I need a tow.
I do have a compressor, plug kit and goo but I haven't put it in the car yet. I guess I should.
Old 03-01-2014, 09:28 PM
Bigdog9586
Bigdog9586's Avatar
Why didn't you just spring for the all season Michiums run flats? I love mine.
Old 03-01-2014, 09:35 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
I was on the fence with that one. The Michelin RF all seasons are an older tire and the A/S 3 has been getting stellar reviews.
Also, RFs do not do well with potholes. They are very easily ruined.
I find non run flats more capable of surviving bad potholes. That is also the reason I decided to get the 18" - 19" set up vs putting tires on Z51 size wheels. The extra inch in diameter gives the tire a little more distance from street to the rim.
Old 03-01-2014, 09:41 PM
LIE2ME
LIE2ME's Avatar
Received 4,558 Likes on 1,640 Posts
I understand the C7 has self programming TPMS sensors as well? If true, you would not have had to program the new wheels when you mounted them, just balance, mount, & go...
Old 03-01-2014, 10:01 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
Correct. I just put the wheels on the car with the new TPMS and the car recognized them in a few minutes. So easy.
Old 03-02-2014, 01:02 PM
C7Joy
C7Joy's Avatar
That works, looks good. Love that Kalahari interior with the roof panel removed.
Old 03-02-2014, 01:23 PM
Tide Will Roll!
Tide Will Roll!'s Avatar
Currently have the A/S Plus RF's on my C6 and will need tires soon.
Thinking seriously about getting the A/S 3 non run flats this time. The A/S plus has been a great tire but it just does not look like a tire that belongs on a Corvette
Post some close pics of the rear view please
Which compressor kit do youse guys use?
(forgive me for posting in C7 section-I lurk here because I will get a C7 at some point. Right now it's just not feasible for me to trade up....
To Running cold weather friendly rubber, what a difference!
Old 03-02-2014, 03:55 PM
Kyflyer
Kyflyer's Avatar
I use the Dynaplug Pro Extreme plug kit
http://www.dynaplug.com/products.html
And the VIAIR 90P compressor
Old 03-02-2014, 04:03 PM
sajonf
sajonf's Avatar
So the base wheels do fit over the Z51 brakes!
Old 03-02-2014, 04:26 PM
entologix
entologix's Avatar
Congrats...I love My A/S 3's as well.
Quick Reply: Running cold weather friendly rubber, what a difference!
