Z51
Old 02-21-2014, 05:48 PM
back into vettes
back into vettes's Avatar
Default Z51
What is all included in the Z51 package for the C7?
Old 02-21-2014, 05:58 PM
jackhall99
Support Corvetteforum!
jackhall99's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
It includes larger 19 " front and 20 " rear wheels, dry sump oil system, Electronic Limited Slip Differential, larger front brakes, black calipers, different shocks, springs and stabilizer bars, differential and transmission cooling, Aero Package, Michelin® Pilot Super Sport ZP tires, HD Cooling, Slotted Brake Rotors and performance gear ratios.
Old 02-21-2014, 06:00 PM
george vee
george vee's Avatar
Received 1,073 Likes on 532 Posts
2015 C7 of the Year Finalist
Will also put a big smile on your face.
Old 02-21-2014, 06:02 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
If you scroll down this page roughly 2/3 of the way to the bottom, you'll see complete details.
http://www.chevrolet.com/corvette-stingray.html
Old 02-21-2014, 06:06 PM
jackhall99
jackhall99's Avatar
Thanks. I should have done that as the site is more informative overall.
Old 02-21-2014, 06:21 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,076 Likes on 6,173 Posts
From the online order guide:
Z51 Performance Package, includes (J55) performance brakes, (J6A) Black-painted calipers, slotted brake rotors, (Z52) dry sump oil system, (FE3) Z51 performance suspension, specific shocks, springs and stabilizer bars, (XFJ) P245/35ZR19 front and P285/30ZR20 rear tires, (Q7S) Silver-painted aluminum, 19" front and 20" rear wheels, performance gear ratios, (G96) Electronic Limited Slip Differential (eLSD), (KNR) rear differential cooler, transmission cooling and an Aero Package
Online Order Guide
Old 02-21-2014, 06:45 PM
Sunny_M3
Sunny_M3's Avatar
...and some complimentary Jack Daniels sitting on the passenger seat!
Old 02-21-2014, 06:56 PM
T_Bone
T_Bone's Avatar
Your post with your screen name above the post about the guy who got his vette backed into made me chuckle.
Old 02-21-2014, 07:14 PM
Blackdevil77
Blackdevil77's Avatar
All for $2,800 bucks. Best bang for the buck ever!
Old 02-21-2014, 07:35 PM
DalTexVette
DalTexVette's Avatar
So true!
The Z51 Performance Package (available on 1LT, 2LT or 3LT), elevates Corvette Stingray to its top performance level. This package includes:
larger 19-inch front and 20-inch rear wheels
dry sump oil system
larger front brakes (13.6 inch vs. 12.6 inch) with black calipers
unique Aero Package that reduces lift for high-speed stability
Michelin® Pilot® Super Sport® ZP summer-only tires (DISCLOSURE) that are aggressively tuned to provide outstanding handling, grip and road-holding capability
available Magnetic Selective Ride Control and Performance Traction Management
HD Cooling
Performance Gear Ratios
Z51
Old 02-22-2014, 01:31 PM
RickMN
RickMN's Avatar
The Z51 wheels are also of a differing (some say better looking) style. Standard is a 5-split spoke style and come in Silver, or optionally Chrome or Black.
There is also an optional Torque style wheel for the Z51.
Old 02-22-2014, 02:37 PM
MikeC4C5C6...C7
MikeC4C5C6...C7's Avatar
OP, I strongly recommend you check the several posts about the magnetic selective ride control that is available as an option with the Z-51 package. Consensus is it is worth it if you can afford it but not unanimous!
Old 02-22-2014, 02:41 PM
ATX-C7
ATX-C7's Avatar
Originally Posted by DalTexVette
So true!
dry sump oil system
HD Cooling
Z51
All of this is worth it!
Best upgrade bang for the buck--get the Z51 if $$ permits
To Z51
Quick Reply: Z51
