Free GM Alignments
Free GM Alignments
I just came from my Chevy dealer where I got an alignment on my C7. And, I found out something interesting. It seems warranty will pick up the cost of your first alignment if your car is under 5,000 miles. It helps to have a reason, like my rear tires were wearing uneven by 1/32 less on the inside of the tires. I found this out from my salesman. The service writers didn't have a clue, but the service manager did.
That is good to know. On my last car I had the first alignment done under the 1/12 "adjustments" warranty period.
That was the case for C6s and perhaps before that. Many are not aware that the service is available. The factory alignment is just an approximation. I'm waiting to see if PFADT or someone comes up with street alignment specs like they did for the C6.
WHAT!? where can I have this in writing.
and how about the alignment thing? because if I go and tell them this, I will mostly get a blank look and will be told "don't believe everything you see on internet forums"
GM warranty has always covered alignments up until a certain mileage to address customer complaints. The only stipulation was that the car must have over 1000 miles to allow the "green" suspension parts to break in and settle. In recent years dealer Service Managers have been given broad discretion to authorize repairs regardless of miles.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
...been that way for quite a few years now with Ford products....GM shouldn't be any different. Well, except for the bailout issue
But not at your choosing. Your oil life monitor has to be at a certain percentage. My dealer told me between 5-10%. That would be about 7-8k m iles before my first change. I might have to do it TWICE before then myself.
Ask your service manager. Mine quoted a reference number to the service writer ( I don't remember it) for the coverage.
Warranty claim processing requires the "3 C's": Complaint, Cause, and Correction.
"Complaint" could be "car drifts to the left" or "tires wearing unevenly", etc..
"Cause" would be "incorrect alignment settings" or "incorrect camber or toe".
"Correction" would be "perform 4 wheel alignment".
Be sure to have over 1000 miles so they don't turn you away until the suspension is broken in.
Not to start an oil life thread, but if you're driving the car regularly changing it based on the OLM is perfectly fine. Synthetic lasts a long long time. If the car is sitting then change it annually. The old "every 3000 miles" is just that... old.
Received 7,753 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Good to know....I'm having my Lashway carbon fiber side skirts and front splitter installed next week. They are also going to lower my car on the OEM bolts. I want to have an alignment done after lowering the car.
This is good to know, as I can't see how the factory alignment can be that accurate. Those cars are aligned in the factory after only being on their wheels for less than 30 minutes and driving less than 100' (over some bumps to 'settle' the suspension). They look like 4-wheelers sitting in the alignment station... no way the suspension is at its long term settled condition.
