Free GM Alignments
I'm not saying this is the case but if it's like many other car factories. the suspension is probably set to some predetermined setting (no alinement) and then farther up the line put on a stationary roll test machine where it is taken up to a predetermined speed where various functions are checked without the suspension ever being aligned. If something on the machine leads them to believe something is out of alignment, then the car is taken off line and manually aligned. Corvettes assembly plants might be different, so I could be wrong on this one.
Drove my car home to Phoenix from the museum. It pulled a bit to the right the entire trip. I took it in and they did a 4 wheel alignment for free - @1,800 miles.
Chevrolet Complete Care
Link below lists all that comes with Chevrolet Complete Care (and that comes with the Corvette)>
http://www.chevrolet.com/comprehensive-coverage.html
Why do you change it so often? You can easily go 10-15K on a good synthetic, with maybe just a filter change in between.
Then why do those same engineers program in 7-8K interval change warnings for the car on regular dino oil? And do engineers not use the internet? Because I have gotten my personal philosophy on oil changes from engineers online. And who do you think designed Mobil 1? Hair stylists?
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Use the search function...it is your friend.
Depends on the dealer. I talked with my service rep who said they don't care when you do the free oil/filter changes as long as you don't try to do more than 2 a year. Now this may have to do with a special "Concierge Plus" program at my dealer, who extends the free service for up to 5 years for the original owner. (Car has to be bought at the dealer, of course.)
I'm Batman..
Pro Mechanic
Getting back on topic here, i wonder if i change out my lowering bolts with aftermarket ones to get an extra half inch on the lowering if they would still do my alignment check under warranty. I would assume not, but i have also never had a car that was allowed to be lowered by the manufacturer to begin with..
You can't go to the dealer and just request an alignment, you must have a complaint or warranty would not pay for it.
Warranty claim processing requires the "3 C's": Complaint, Cause, and Correction.
"Complaint" could be "car drifts to the left" or "tires wearing unevenly", etc..
"Cause" would be "incorrect alignment settings" or "incorrect camber or toe".
"Correction" would be "perform 4 wheel alignment".
Be sure to have over 1000 miles so they don't turn you away until the suspension is broken in.
I wonder if they will still do the alignment.
#33
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Most car manufacture have 12/12,000 miles for free alignment, with concern.
#34
I'd have to challenge the above statement about the C6 being under the same program as the new vehicles. Check out the link posted in this thread in a later post and it specifies "a new 2014 vehicle purchased after May 1, 2013" I bought my '13 C6 last year in late June and did not get any free regular maintenance offer on it. Of course, I could have paid extra for that program, but it's certainly not free. It'd be interesting to see if you can find the same kind of reference for a pre-2014 vehicle as the one for the new Vette.
#35
Why would you want to do the alignment if it did not need it? You're just taking a chance of some service tech screwing something else up or even making the alignment worse than it was. Also, I wouldn't want to waste my time just to get something done for FREE, for something that's not needed.
#36
Yes, there is always the risk of Chevy service making it worse.
I usually take a new car to my usual Alignment shop, where that is their specialty and I know it is in good hands.
Still trying to decide which option to take when the time comes.
#37
Not to rain on anybody's parade on the oil change but that's GM Dexso oil not Mobil 1 that will incur an up charge. I had my SS changed under 1000 miles as I do with all new cars and they wanted me to wait till the change oil light came on no thanks. I bring my own Mobil 1 and filter they kindly did mine no charge since I had oil and filter UPF48R I think it is use the same on the z06.
z51vett
Doug
z51vett
Doug
#38
On your window sticker under "Standard Equipment"... (Oil/filter change)
#39
The factory alignment is a little aggressive so if you want good tire wear have street alignment specs done saves the tires. 09 Z06 had tires gone at 8000 to 10000 miles second one 2012 at 500 miles had street specs done got 14500 miles out of stock tires have 12000 miles on the Mich tires still got good tread may make 20000 on these.
z51vett
Doug
z51vett
Doug
#40
