Will headers void warranty
I was considering putting some headers on my C7 and have been told by a Chevrolet dealer that if I did it would void my warranty. Some of the people that sell the headers tell me it varies from dealer to dealer. Kind of confusing to say the least.
Does anyone know if putting headers on my C7 will void my warranty. Thanks
It depends on your dealer.
I know that's not what you were wanting to hear. Some dealers will overlook the fact that you have headers on the car unless they can give good reason that those were the cause of any problems you had. Talk to the service manager at your dealership, or go around to a few dealerships and ask them the same question.
Just know that any aftermarket performance parts you add may have an affect on your warranty.
IF you have the dealer install the headers then most likely they will warranty the work and any problems. However, if the headers cause extra work during the warranty time it would be only fair that you pay for that extra time the mechanic needs.
Farva0066 (01-10-2024)
It ok with some and not with others because the dealer makes the decision and the mfr goes along with it. But a mfr can "call for the parts", and you have to produce them. The mfr can then re nig the payment if the parts don't show it's legit.
So some dealers say no to avoid the hassle.
The tune will be the thing that voids a powertrain warranty.
In the even of a catastrophic failure, the dealer gets taken out of the picture. Regional reps from GM get involved and the techs will send evidence of no foul play to GM when authorizing a replacement engine.
If the flash counter/checksum whatever other evidence from the ECM doesn't match the replacement will be denied in most cases.
This won't effect your warranty as far as electronics like radios, window motors, seats, etc.
This makes no sense to me that a header system would void a warranty....HOW??
So if you put a cat back system on it voids the warranty? The exhaust performance would only improve the performance of the car, the only logical connection to a failure would be due to a lean condition from a car making more power and the DME not correcting for fuel.
The other point that I think some owners fail to consider is that some sets of headers delete the set of cats closest to the engine, the cats that probably do most to clean up the exhaust. Hard to think that it’s legal to delete any cats and might, I repeat, might cause you to fail an emissions test.
I love increasing the performance of my cars w/o compromising the warranty as much as the next guy but screwing with the emissions configuration just isn’t right in my view. Don
who cares. if something really bad happens to the engine, i'd go out and buy the 480 hp crate motor. and then i would put new headers on that. actually for a few grand more you can buy the 515 crate engine.
The other point that I think some owners fail to consider is that some sets of headers delete the set of cats closest to the engine, the cats that probably do most to clean up the exhaust. Hard to think that it’s legal to delete any cats and might, I repeat, might cause you to fail an emissions test. .... Don
It is the tune of the ECM that will that pretty much required with long tube headers. Mid-length headers like the ARH ones do not relocate the O2 sensor further downstream like long tubes do, which is what causes the CEL.
This CEL is what you must tune out.
I really wish that there were easy ways to get performance gains w/o getting crosswise with the dealer or GM but that doesn’t seem to be the case. That “permissible” upgrades aren’t easy to accomplish is probably a compliment to the engine engineers at GM. Don
Isnt there something somewhere like maybe the Magnuson Moss warranty act of about 1975 which says its not just the modding of something that will void your warranty but what ever you did must be shown that that change was in fact the reason for your motors problem. I think its been mentioned here on the Forum several times. But I also think when you mod your vehicle and the vehicle is under warranty you are asking for trouble/fight with Chevrolet/GM.
1 Post
I did some minor mods to a couple of my C5's - Halltech intake and Corsa exhaust on one, and Z06 exhaust on my 2002 coupe. Dealer told me "No problem, just don't expect me to fix a part if it breaks." I've left three C6's stock, and have no plans to mod my new C7, which I'm told has a pretty decent header setup already.
As someone said, you will pay to play - and I'm told that if you change the tune, and then flash it back to stock, the dealer can still tell you fiddled with it.
Want more power? Wait for the new Z06, or buy a used ZR1. imho.
1. A Cat-Back is not the same as a header
2. Your warranty can't and won't be 'voided', the price of the warranty is built into the car. To void the warranty GM would have to return some money. They can, however, deny warranty coverage due to modifications that are directly related to the failure.
3. Magnusson - Moss Act is a joke and is mostly related to air filters, oil, spark plugs and such. While it does say that the manufacture has to prove that the aftermarket part caused the failure, they will put the onus on you .... who has the deeper pockets and all the technical data, you or GM.
4. Other than a shorty header, all headers, whether federal or California emissions violate federal law by either relocating or by owners deleting the cat convertors.
5. Just because your dealer turns a blind eye to modifications as they relate to the drivetrain or suspension etc. doesn't mean another dealer will or GM. GM has the final say and GM is cracking down on this practice.
While most people believe headers to be a failsafe mod, there have been cases where that hasn't been true.
A. Burned spark plug boots.... easy fix, but still your dime.
B. Headers burn clutch hose that goes from the frame to the slave cylinder, it's happened more than once or twice. Not a cheap or easy fix.
C. Install headers, no tune, burn a valve .... maybe extreme, but in the ever tightening window of emissions and MPG, you decide.
D. You put headers on it and one night you turn off the nannies and get on it and bust the diff from wheel hop. Now this can happen even without headers, but now you have them and the dealer says the headers added too much HP..... who wins this argument.
This is all just food for thought and help the decision making process.
