Stone/road debris protection results?
I am about to fit a set of ACI 01 side skirts in the hope it will eliminate or at the very least minimise paint damage to the rocker panels, door jambs and rear mag wheel spokes from debris thrown up by the front tyres. I already have the GM front splash guards fitted.
Can anyone provide feedback as to the effectiveness of the side skirts in reducing of eliminating damage from material thrown back by the front tyres?
Will I be able to remove the clear plastic panel protection material factory fitted on my Z51 which now looks very tatty from rock damage?
The C7 Z51 and even more so the Z06 have what are probably the stickiest OEM tires on the market. They do an undeniably excellent job of holding the car on the road. That said they're going to pick up everything they can an throw it back. It's a Corvette !!! Expect some road rash on the factory protection, I'm happy they used such a heavy thickness. A friend following me too close learned the hard way what the tires are capable of picking up and throwing back. It cost them a severely pitted (stared) windshield after the rock pitted the hood near the heat vent.
I installed rocker skirts the day I brought my C7 home. My experience from my prior Vettes (3 C4s, 2 C5s, 2 C6s) was that the rockers and rear quarters get pretty beat up with road debris. My 2011 GS, with the sticky, Super Car tires was the worst. So, when I saw the C7 Z06 at the NY Auto Show in March, and saw the side skirts, not only was I impressed with how they improved the look of the car, I believed the protection factor they offered from the road debris issue would also be beneficial. After 5K miles on my C7 with skits in place, I can testify while any aero benefit may be questionable, the road debris issue is vanstly improved. Absolutely no rocker damage on my C7. The GM Wheel Arch Guards (Mud Guards) also help with the rear quarter.
Save the Wave - - - Al
Do you know where I can purchase new OEM factory replacement protection pieces?
You'd be far better off going aftermarket. Xpel Ultimate seems to be the popular choice on this forum, but I have 3M Scotchguard Pro and am very happy with it. If you are only doing that area it will cost you next to nothing I'm sure. And it won't yellow like the OEM piece.
side skirts are extremely helpful in the road rash dept. I also covered my skirts in XPel.
Former Vendor
Road Warrior Plus is another option for short to medium term applications to protect your paint. We just joined CorvetteForum as a new sponsoring vendor. Road Warrior Plus is a state of the art temporary roll on paint protection for any surfaces on your car that might be subjected to debris, dirt, tar, stones, etc. encountered whether you are on the interstate on a trip, or have headed to the track.
It rolls on like paint, dries quickly with a clear but slightly matte finish, protects with a rubbery film, and can be easily removed when you are ready to show off your perfect paint.
A quart container will cover the front of a car about 5 times and costs only $39.99.
For more information, go to www.roadwarriorplus.com
You can view a quick video of the product here:
Here's a quick overview of how the product is applied, removed and protects.
As others said, skirts snd splash gurads do the job well, i did 3000 miles recently and not a mark. I use peelable plastidip clear for other areas still open, like behind rear wheels,etc. Peel off when i get there.
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
Carbon Fiber Roof, Side Skirts and Hood Vent
To remove the factory ppf pieces that are right behind the doors, you'll need a squirt bottle ( johnson&johnson baby shampoo & water) & a heat gun. You should clean everything first, maybe even use a clay bar to get all the grime & road debris off the vehicle. Then warm up the PPF & the body panel as well using the heat gun. You goal is to get the area your working on around the same temp. as it would feel like on a summer day. Be gentle when heating everything, don't over heat or spike the surface temps on the vehicle.
Once it's warmed up then focus on a corner of the PPF & pick with your fingers until you get a corner peeled up. Then with one hand on the ppf & the other on the heat gun start heating up the PPF while you pull outward away from itself almost parallel with the body panel but slightly at an upward angle. Do not pull at 90° from the PPF or body panel. Your simply stretching the PPF & in doing so stretches the adhesive until it becomes no longer effective & separates from the body panel.
be careful of your heat, never leave the gun pointed at the same position on the car, take your time & when any portion of the PPF separates from the body panel spray your soap solution inbetween the PPF & the body panel so that it won't reapply itself back to the panel.
Good luck.
Wormwood
Good luck.
Wormwood
I had Lashway side skirts and the larger GM splash guards installed at the dealership before I took delivery. Car has 6,000 miles and the factory protection on the rear rocker has 100 of chips. Even has some on the paint around the protection. Michelin PSS + Minnesota roads = bad news for the paint. I am going to have a local shop replace the factory crap with Xpel (they make a custom set just for the rockers:
