Auto Transmission - speed vs. rpm
Old 01-18-2014, 10:48 AM
fredmills
fredmills's Avatar
Default Auto Transmission - speed vs. rpm
Does anyone have data or a chart showing speed vs. rpm in each gear for auto. transmission or, at least, speed at 6500 rpm.
Old 01-18-2014, 12:47 PM
W88fixer
W88fixer's Avatar
TRANSMISSION OVERALL
4.03 10.32
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
Rear axle 2.56 (base model), approx 1507 rpm @ 70 mph, tires 245/40X18 front, 285/35X19 rear
For speeds in gear, you can do the math as you choose. Don
Old 01-18-2014, 05:07 PM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
Not sure of what you want but here is the WOT shift points for both Speed and RPM for the C7 A6. I believe both have to be satisfied for it to shift.
Name:  C7 WOT shift points.jpg
As you can see, at 5000 RPM's and 169 MPH it will be shifting to 6th gear at WOT.
Old 01-19-2014, 01:39 PM
fredmills
fredmills's Avatar
4.03 10.32
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
Thanks. very helpful.
Old 01-19-2014, 01:50 PM
VETJAZZ
VETJAZZ's Avatar
FWIW - my stock C7 cruises at 95 mph @ 2,000 rpm.
Old 01-19-2014, 07:42 PM
~Stingray
~Stingray's Avatar
St. Jude Donor '17, '19
Thats crazy.
Old 01-19-2014, 10:19 PM
///ADMAN
///ADMAN's Avatar
Engine Brake @ 6500
Speed = Zero
Old 01-20-2014, 01:11 AM
Zurbo
Zurbo's Avatar
Check out my post here for RPM vs MPH for A6 vs M7 performance ratios vs the A4 in my SS.
http://forums.corvetteforum.com/1584616957-post26.html
Old 01-20-2014, 09:27 AM
fredmills
fredmills's Avatar
Great charts. Thanks. Simple conversion to base car (2.56 vs. 2.73) is 1.066. Base car will run higher speeds, but of course longer times.
To Auto Transmission - speed vs. rpm
Quick Reply: Auto Transmission - speed vs. rpm
