Bit of Color Under the Hood
The injector covers do just pop off - pull them on the inboard side and two rubber grommets release and the covers are removed. The plenum cover is held by 4 bolts removed with 10 mm deep socket. Prior to pulling that you also need to release the injector wiring harness on each side (which is a bit of a challenge but doable) and unplug one connector on the driver's side. Paint and reverse to install.
I do like color under the hood. Again another area where some say its a waste of money. I have never had cars as a good investment, although that would be a great thing. Its just a fun thing for me as it is for many.
I also have more color parts ordered.
mksZ51: would recommend a coat of heat-capable Torch Red for better color matching. That shade of red is just off enough to look wrong. Readily available from at least one or two forum vendors.
I appreciate the feedback - I'm must not that picky under the hood. Neat, tidy, and clean with a splash of color is good enough for me.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
