2014 corvette stingray track preparation
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
The 2014 Corvette Stingray with the Z51 Performance Package has been designed and engineered to be a world-class sports car for the track. But before unleashing its acceleration, cornering and braking capability, there are several key procedures and steps that must be taken in order to properly experience its track prowess. For full details and information, see the vehicle Owner’s Manual.
Check out the attachment!
jrzybil (01-26-2018)
Interesting...
This is almost exactly what I used to do on my 1999 Z51 coupe when I tracked it. I drove it 115,000 miles combined street and track and it was running stronger than new when I sold it.
Here is what I used to do:
- Use Mobil 1 15w50 oil
- Bleed brakes 100% with Valvoline synthetic DOT 3/4 fluid every 6 months or 4 track days whichever was sooner
- Set alignment for track use
- Change manual transmission and differential fluids at least once per year
- Change clutch fluid to Valvoline synthetic DOT 3/4 fluid and replace every 4 track days
- Replace brake pads and rotors every 2-4 track days depending on the track
- Rebuild brake calipers every 6-8 track days
- Replace power steering fluid every 6-8 track days (we don't have to worry about this one any more)
Great summary and info!! Thanks for posting.
Some items... like changing brake fluid back to OEM for the street, etc... I will skip but the vast majority of this is great info.
Does anyone happen to have the stock alignment specs. I hate changing back and forth. I usually try to find a compromise that gives good on track performance without killing the tires on the street. Very nice to have a recommended set up though to start with.
Ken
Ken
Originally Posted by track junkie View Post
The Corvette Stingray Z51 will arrive at the dealership with a package of aluminum rings and wire. These are called out as brake rotor cooling rings. These rings are to be provided to the customer and are not to be installed during the PDI process. The cooling rings are for customer use if they elect to use the vehicle in a competitive driving event. The directions are outlined in the 2014 Owners Manual under "Competitive Driving". The rotor rings are for off road use only and must be installed to prevent brake fade in competitive events.
Caution: Do not leave rotor cooling rings installed after a track event, as this can cause corrosion with long-term use. Rotor cooling rings are for race track use only. Race track driving without the rotor cooling rings may result in brake pedal fade.
Installation:
1. Remove the front wheels.
2. Cut three 150 mm (6 in) lengths of safety wire specified to T304 Stainless Steel, 0.041 in nominal diameter, not included.
3. Form each into a U shape with a 20 mm (0.75 in) flat area in the center of the wire.
4. Place the rotor ring in the gap between the rotor brake plate and rotor hat, with the holes on each side of the rotor spoke on the outboard side of the rotor.
1. Place the U-shaped wire through the holes in the rotor cooling ring.
2. Bring the ends of the wire tight around the corresponding rotor spoke.
3. Twist the safety wire into six to eight twists per inch.
4. Bend the twisted wire so it is flush with the inside of the rotor ring to prevent contact with the caliper or brake hoses.
5. Verify that the rotor rings and safety wire do not contact any other components.
6. Reinstall the wheel using the specific lug nut torque. See Capacities and Specifications in SI.
If additional brake cooling is required, the grill mesh in the lower corners of the front grill in front of the brake duct can be removed. This is not reversible, and a replacement grill will not be covered by the warranty. If this is done, it is recommended that the gap between the fascia and the cooling duct be taped over.
Obviously the idea behind this is that the air being ducted to the center of the rotor will be trapped by the band and directed through the rotor instead of partially by passing. These rotors do not appear to be vented directionally. Time will tell, but this looks like an add on fix for fade problems.
Cheers,
Ken
Installation:
Cheers,
Ken
In warm climates like CA and FL I think it is fine to leave the 15w50 oil in all the time. You may see a slight drop in MPG but the thicker oil should not hurt anything as long as temps are 40F+.
As for the brake disk rings, I would think it is OK to leave them in as long as you are not driving the car in the rain and you be sure to dry out the disks with some compressed air if you wash the car.
Question for you seasoned vettes... My car is not a Z51, nor do I plan to "track" the car. What I do want to do is take my car on a closed road coarse and drive it legally over the speed limit. My C5 was a Z51, my C6 wasn't but it had an upgraded suspension, and they both were "driven" on open country roads when I lived up north.
Is there a prep recommendation for guys like me who just want to get out and play for a day or is there a special class or track day I should look for?
I plan to follow instructions for before tracking the car. The only thing I see doing after the event is removing the hub rings. I always check fluids and brakes afterward anyway, so removing rings should not be a big deal. I agree their is no need to switch back the fluids. I would go back to recommended weight oil at the next oil change unless you have another track day coming up.
