New engine?
Understand. On a side note......unless his state has lemon laws, I'd be hugely surprised if GM agreed to that. And even then, I'd be surprised if they didn't fight it tooth and nail ("Hey, we've agreed to replace the entire engine over a silly coolant leak")
Anyway...........
Anyway...........
New Mexico does have a lemon law, it's four repair attempts on the same problem, or more than 30 days out of service. I doubt lemon law would fly and the dash rattle, though it's already been in four times for that :-). We'll see how long I'm waiting on the new engine.
How many miles on your car?
Oh, come on, guys. A new car?! You serious?
It's a freaking engine leak. The engine doesn't make the car. ALL of the car makes the car. If anything else isn't broken, especially anything detrimental to the car, why would they replace an entire car over something that can be fixed with a a new motor? That's just ludicrous. What are they going to do with the rest of that used car? Place another motor in it and sell it at a major loss? GM isn't going to replace the car and the dealership definitely isn't going to give up a car over warranty work.
Come on, people. It's not a big deal to replace a motor. It's not going to change anything about the car. All the motors are the same now.
if the engine isnt mated absolutely perfect to the torque tube, the engine will fail, and you will need another engine.
the tolerances are very slim for the connection between the tube and the engine
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Well, before I even started dating my wife, we were spades partners in college. Our column on the score sheet would be titled "JAG" when we would play. My name is Jeremy and her name is Gina, thus the JAG for Jeremy And Gina. Well, we have five kids now so now we're not just JAG, but JAGAMAJAJARAN (using the first letter of each of our first names in order by age). And since it can actually be pronounced as a six syllable word, we use it to represent the Magnificent Seven who make up my little family!
z51vett
Doug
It would be great ideal if GM would buy the car back, but it's going to be quicker to have them replace the engine. The car is under warranty and it can't be that that hard for a competent tech to install a new engine. There have been a number of rear end replacements that solved problems and the owners weren't demanding a new car. I think you should try to let the dealer make the repairs authorized under warranty rather than fight them. A numbers matching C7 isnt going to make a bit of difference in its value if you trade or sell it. I'd go for the avenue that gets the car back for you to enjoy the fastest.
Chances are the y will replace the engine, and if the OP thinks he has a rattle now, just wait.
Went thru 2 engine replacements under warranty. One on a 69 RoadRunner in 69, and once on a BMW in 2000. Just not the same, and naturally they said I had the best working on it. Long Block or SHort Block? Be nice if they just gave you a new car but very doubtful.
I would like to know if this motor replacement issue would show up on his car fax report? Would you purchase his car, let's say four years from now with this on his car fax?
#34
If there's a crazy tight tolerance, then I'm sure that the bolt pattern that lines up the bell housing and the engine is super tight too, to prevent any deviation from the spec tolerances.
MANY Corvettes with this layout have undergone part replacements that have required the torque tube to be detatched from the engine. I'm pretty sure the OP will be OK.
#35
They (GM) probably want your engine to see what made it fail . and make sure it didn't happen again with future cars being produced . This is good for others , but not so much for you . As for a buy back , a friend of mine , (after my constant insisting) had a c6 vert with a terrible silver paint job (bad modeling on both sides and decklid) was bought back for for every dollar he paid , including tax after 3 months of use (We both worked at a GM Plant)... But he had to buy another Chevrolet product . This was at the end of the C6 run and couldn't find another Corvette that suited him , so he ended up with a killer 1 of 86 Hotwheels 2SS convertible , 6-speed manual , Camero . Hope they do the same for you ...
#36
I find this very hard to believe because the clutch is up front. You still have to drop the torque tube to get to the clutch when you replace it.
When they put the tube back, there was a very small variance, the cam wound up being marched out of its sitting, and car wound up stalling due to computers not being able to detect RPM's, which was because the cam was moved forward and out of position.
the stalling and loss of RPM signal was a symptom- in the end the engine had to be replaced.
If I find that thread here, I will link it.
#37
Received 19,435 Likes
'20-'21-'22-'23-'24
#38
#39
Not really. I'm just the kind of buyer who doesn't like hearing or seeing documentation that the mileage on the car isn't the same as the mileage on the engine and that somewhere in the past there was a significant issue with the car. When I buy or sell a car, I like full disclosure, and a replaced engine on a late model car has always been something that I have avoided. I know there are other buyers out there like this, which can affect the resale.
#40
Replaced Engine = Major Repair = Diminished Value
Trade-in and or private sale in future will take a hit because of this on the GMVIS report. Car's history will have a major blemish, causing future buyers to either ask for deep discounts or buy elsewhere.
